The engineers who designed these printers, in their infinite wisdom, decided to look at the printer from the side on instead of front on. So the Y direction is actually left and right when looking at the front of the machine. Just FYI. It's definitely counterintuitive but pretty much every tech you speak to will refer to left and right as the Y coordinate. White Haus's link should help for sure.I did consider doing that test but was thinking this would only adjust the side to side bi-directional alignment. The problem seems to be in the Y direction which is up and down...like a stepping issue.
But i am not have general stepping issues as the colors align with themselves fine
