Mimaki UCJV 330-160 white ink alignment to color ink
DuggieJ
I am new to this printer and cannot find out how to align my white ink to the color ink when 2 layer printing. The white is off in the Y direction. I tried choking the white in Rasterlink but it is off too much. It needs to be aligned on the printer. Any thoughts?
The first thing to check is the bi-directional alignments. It's called "Drop Position Correct" on Mimakis.
Smoke_Jaguar
The 330 series also has the automatic calibration patterns that can be a huge help. Good to run those for different thicknesses of materials and save a profile in the printer for each.
DuggieJ
I did consider doing that test but was thinking this would only adjust the side to side bi-directional alignment. The problem seems to be in the Y direction which is up and down...like a stepping issue.
But i am not have general stepping issues as the colors align with themselves fine
The engineers who designed these printers, in their infinite wisdom, decided to look at the printer from the side on instead of front on. So the Y direction is actually left and right when looking at the front of the machine. Just FYI. It's definitely counterintuitive but pretty much every tech you speak to will refer to left and right as the Y coordinate. White Haus's link should help for sure.
DuggieJ
your tip worked perfectly! Thanks so much! I am new to rasterlink as well...so I am pretty green at this software. Thanks for reaching out so quickly.
Reactions: 1 users
White Haus
Not a Newbie
Glad to hear that worked! I haven't used Rasterlink in years but remember that being an issue and they thankfully designed a fix for it.
