Not sure if this is a related question, but I am not clear what the second Sub Power switch is for on the printer? Referring to the main 120V power coming in, and two main rocker switches. The main one seems to power up everything, and supplies the Power supply. I see the manual says to switch off the Sub switch first when powering down. But I am not clear what that second sub power line does inside the machine.
So far I can confirm that 36V is at the start of the station iv PCB, and on both sides of Fuse 1. The 5v power supply is outputting 5v, but I have not been able to confirm 5v at this PCB yet. I believe F2 is supposed to have 5V, but has 0. I will work on trying to understand the path it is coming going and checking these voltages you both suggested today and reply back.
Thank you!
Thank you!
