More Window Graphic Pricing
Tagdog
I posted a couple days ago about an insurance company that wanted 8 windows done. Signs 101 helped a lot. II ended up eliminating some of the logos, going up on what I orig. thought but still less than what I should get. The cust had a much cheaper bid but went with me since I took the time to go in person and explain things. Now I have another window for the same person and I would like a little fed back.
Windows are 41 x 68 there are two together so the working space is 82 across x 68 tall.
Green vinyl is a Pantone color I would have to order or I could digital print it. Either way a lot of expense.
Plus I would have to do a Logo and Store hours on the door.
If I did this, would it be best to tile it in small squares 14 x 14 or try and do 68" x 14" panels? Or is there a better way?
Price? 400.00 - 500.00 ?
My wife thinks we can cut and mask everything in 1 hour, I think it will take 3 hours plus 2 - 3 to put it on.
I really don't have enough experience yet to estimate the time it will take.
Thanks in advance
Signs Up
Learn to tell a customer that when cutting vinyl.... no one can get exact PMS color matches. You always go for the closet roll that will match in color.
I agree with your wife. Looks like it will take about an hour to cut, weed and mask.
Should only take about 1/2 hour to install. with your inexperience.... allow an extra 15 minutes.
Don't forget to charge for travel time, set up and take down any ladders or other things you will need in your installation.
41" is not that hard to handle. Just hinge it at the top and drop it like a piece of wall paper and you'll have both done in no time. Be sure not to take anything right up to the very edge where the rubbery gasket is. Keep everything about 1/4" in from that.
I would think between $400 & $500 should be just fine.
:thumb:​
Tagdog
I only have a 24" cutter. But I do have a 54" Summa DC 4 that will print the color she wants and cut it out. So if I do a whole 41" window. The biggest roll of mask I have is 30". Do I need to get a bigger roll or can I double up with what I got. That sound like a stupid question but I've never tried it. Everthing we have done is smaller. So if I start at the top, I guess I just have to work my squeege back and forth making sure everthing lays flat and even?
Signs Up
Tagdog
I kept thinking I would have to tile it. If I can put it on in one piece it makes a big difference.
Mark
Malkin
Seaming the mask is fine. There is sometimes a very slight line of small air bubbles left over which you can work out or just leave.
Can you buy 48" green vinyl and run it through the Summa and just use it as a large plotter?
Malkin
Not to derail, but why doesn't it work?
What happens if you send a file that has only cut lines/paths?
Edit: Is the price you were talking about per set of 2, or for all 8 windows combined? If combined, then yes it will take 2-3 hrs to cut/weed/tape. Also, price seems low.
Tagdog
You can just lay down cut paths, but the way the Summa works it prints registration marks and guides itself by them. Colored vinyl will not work. The customer had found some vinyl from Grimco but it only come in 15" rolls, thats why I thjought I would have to tile this and it would tkae me longer. The price I mentioned would be for thes two windows and her logo and hour on her door.
I think I will digital print, weed and mask the whole thing(one window at a time).
If I lay the whole thing on the window, pull back the backing at the top and apply it and slowly start workingmy squeege from side to side slowly moving dow to the bottem, is this the best way?
Usually when we have had to put graphics on windows, they have been
smaller than my squeege, that makes it real easy. I know I'm being kind of over cautious here. If I just go do it I'll be fine. Just trying to get an idea how others would do it.
Signs Up
What brand only comes in 15" rolls ?? I've never heard of that.
If you have to print registration marks... you can always put down the marks...... put white vinyl over it.... re-register it and put the marks down on white and then cut. You need to outsmart your software and equipment if you wanna continue.
Tagdog
There I go not looking at the catalog and getting too many people envolved. You are right. I never looked at the catalog myself. Someone here said "we can get the color she wants but it only come in 15" rolls."
Now that I looked myself, they were looking at something altogether different? So now I feel like an idiot?!
Anyway, yes I could get creative and figure a way to trick my machine into cutting colored vinyl but I think I'll just print it. I'm still more curious about technique of getting it on the window being large like that.
Signs Up
Malkin
Yes, you just work your way down, squeegeeing from the center to the outside, overlapping each pass, in order to be continually pushing the air out, not trapping it. We do oversize stuff like this with the 4" squeegee's all the time.
