Most Basic But Its Escaping Me!!!
vectorterrorist
I am tying to to create a sticker for a motorcycle stand that is 9,5 inches at the top and 10.5 at the bottom and is 5" tall....so it look like a triangle with its top cut off.
I made this using just the line tool...bow I want to round the edges of this....rounding the edge isnt what I have a problem.
what is escaping me is what I need to do to make all four lines become 1 shape. I have tried expanding it and everything in the pathfinder box and nothing works! when I go to add anchors and then delete the middle one it removes one of the lines.....how can I make this become one shape?? its late and common sense is out the window
using illy cs3
thanks
Fred Weiss
Why not just start with a rectangle, set guidelines to modify the top and then move the two corner points to the guidelines on axis?
Biker Scout
Something like this?
Biker Scout
There's a couple of ways of going about this... (if this is in fact what you are looking for.)
Just make a 10.5" rectangle, the got to "Filter : Stylize : Round Corners"
Then make another rectangle, 9.5" wide... center them both up, and use the white selection arrow and grab the bottom corner nodes of the 10.5" rectangle that has been rounded, and scoot them in one side at a time to match the width of your 9.5" rectangle.
:thumb:
