partysigns1
Looking for recommendations for adhesive to attach acrylic to aluminum mount back.
I place the tape around the edge and also vertical strips spaced 10-20cm apart depending on size. Multiple shorter strips of tape (<50cm) are going to make a stronger bond than long full-length strips.Question where do you place the tape. Only around the edges or also in the center?
I'm in Europe, so my main options are Neobond and the original 3A composites. As a backing, it doesn't make any noticeable difference in terms of adhesion—maybe 3A cuts are marginally cleaner.Thank you. What types of backing have you used? MaxMetal? or other brands of ACM?
12 micron polyester film. 3M or Orafol both work equally.Also what thickness of tape do you use? Most of my experience is in metal sublimation and we use a self adhesive PVC cleat system that has been amazing both cost wise (almost the same cost as VHB tape per inch.
