Mutoh 1682sr-p issues
cthulhu68
Hello all
We just got the Mutoh 1682 sr-p and having 2 issues right off the bat.
When printing on vinyl and photo paper ink isn't curing, or maybe laying down to much ink. If you touch printed area to printed area it pulls up ink. We are running 2x ymck ink cartridges for faster printing, which I'm thinking was a mistake maybe. Using Verti RIP and the presets that were downloaded which are 3 avery, ij180. First preset I tried did have lower preheat and platen heat settings but tried others and didn't seem much better. Any tweaks to presets that could help here? I know an ICC profile would be better but I would think one of the presets would work.
2nd issue was when trying to print a banner I get horrible banding. I talked to guy that sold us printer and he said I needed to set up "user type" on printer and adjust media thickness and do a pf adjustment. Was able to find media thickness. He told me to set at 330um for 13oz banner. That didn't help. As for PF adjustment can't find where it is or how to do it. He told me you have it print 500mm then measure and adjust. From what I'm reading this machine has a different auto adjustment called feed master but can't find/ figure out how to do that.
Sorry for wall of text. Any help would be appreciated.
Is this your first solvent based printer perhaps? Your first issue sounds like you're printing on a coated photo paper which won't work with solvent. So if you're printing on paper that you used to print on with water based inks, it won't work. It could be laying too much ink down as you suspect if there is no color profile and you're just working off of presets with no color correction. I'm not sure how Vertilith handles it but, a lot of the time the ink limits and linearization are attached to the color profile but not presets. Find an ICC profile and try it out. That should get you pointed in the right direction.
The PF adjustment is in the User Type menu. Hit the Home button, then Setup, and then User Type. In the User Type menu, you should be able to find PF Adjust. That menu will have the auto and manual adjustment.
cthulhu68
Hi, thanks for response. As far as curing issue, both materials avery 2903 vinyl and briteline photo paper claim to be solvent compatible. Is coated paper really a no go? The rep mentioned "print interval" in the RIP options. (pause between passes) which was something I thought could help giving it more drying time. Will try that Monday and if that doesn't help look into ICC profiles.
Not sure how I couldn't find that PF adjustment yesterday but thanks, I found it. Tried the auto adjust, no help. Tried the manual adjustment, it was 494mm instead of 500mm so I thought that was it, but even that did nothing for the banding. Did nozzle check just to be sure not printhead issue. No issue there. This is Duratex banner which is pretty far from smooth. Looks fine on latex HP but are solvent printers just more finicky with banner?
unmateria
Go to verlith profile editor and linearize it visually (not need i1 etc for this) you have to choose the best patches that doesnt bleed. If the problem still there, try with small dots. Pf, micropf, bidir adjustments etc should be all made manually not auto. At least on my 1641sr, automatic calibrations really suck. And well, i dont know how you calibrate/align both heads, but i suppose it will be in the service manual
cthulhu68
OK. I guess I was spoiled by plug and play nature of HP latex and our Fuji UV flatbed. This is a tinkering man's printer.
Read up in the manuals and I see there's more to do with PF adj. and PQ calibrations I'll need to set up for each material (user type).
I have to download this through the Mutoh Club, right?
Thanks for tips, I'll update after dialing in material and RIP settings.
unmateria
I think it installs already with Vertelith from mutoh club. Anyway if you ask them by email, they have a very good support. Mutoh, mimaki and roland are good machines for finetuning them, so they are not much plug and play, is like having and android or an iPhone mobile. For those who dont want to finetuning anything an accept what the vendor says its ok, go apple or hp. But is a pitty because machines are very limited while they could do much more. For example, your machine can do MUCH better colours (more gamut) than those limited settings on vertelith defaults. Just need a densitometer and know to do it... But is an amazing machine. Ahh, the settings you are looking for are in the user settings on the machine. You can rename them from mutoh remote control too. Is very nice because you can have real costs per media, and fixed settings so non-tech people can use them just selecting what they are going to print. Just dont forget... Dont let the machines to autoadjustments if you want perfect results
cthulhu68
Banner issue solved! The banner profile on Vertelith I was using is 4 pass. Mutoh print mode is at high quality so either a conflict between those or 4 pass was overriding the high quality mode. Just switched to different profile that has 8 pass, small dot and looks good.
Tried adding print interval delay between passes for curing issue on photo paper. Seemed to help but still tackier than I think it should be. Lightly touching ink to ink doesn't lift ink but if you press together still does.
Downloaded Vertelith Profiler so I'll see if I can set up custom profiles at some point.
unmateria
U have to match the media profile on the machine so you never mistake. For example, You make a media called "banner", you make pf afjustments etc on machine and in profile you setup the print height, dryer, and the " banner" hardware profile, so next time you wont forget anything that worked before, or leave the printhead height at minimum or things like that
