Hello, Grant. I use a parallel cable with my FOJ printer and it works fine. I have tried the SEH print server that came with the printer. To get it to work for me, I had to go into the Local Area Connection Properties, right click the TCP/IP, select properties, and then enter a specific IP Address. Then, reboot. Your SEH documentation should give you the IP Address. I'm certainly no expert on this. Hopefully, some of the real pros will put their 2 cents in here. Good luck.
