mutoh vj 1204 dampers
jbennett
I am wanting to replace dampers on my VJ1204. I have taken the covers off, but can't get the piece that the service manual refers to as the damper fixing material that sets right on top of the dampers off. the manual shows simply rotating it up and no screws. Don't want to get rough with it. Any ideas? All help is appreciated.
jbennett
henryp
jbennett
Yes, it has 2 locating pins and 4 locking tabs that just click in place, no screws. For easier removal, unscrew the clamp that holds down the ink tubes on the CR Sub-board. This would free up the ink tubes to give you more space to wiggle it out.
jbennett
Do you like manual to see how you can change the dampers?
I have it. Thanks though. I just cant get the damper cover up. Im probably just too afraid to put enough pressure on it. May have to get someone that has experience.
jbennett
jbennett
OK. After trying to replace the dampers with no success, I now have a printing problem. I am getting what I would refer to as very light but very noticeable cyan colored horizontal "splashes/raindrops". Any ideas what has happened. Have ran multiple cleanings. Is obviously most noticeable on areas of white. All help is appreciated.
Here are pics.
jbennett
