Need Help Mutoh VJ1600 - Error 085 Head Heat major issue
Omega Plotting
Hello, looking for any guidance provided before calling in professional repair.
Printer suddenly stopped printing black ink over the weekend, no error shown. Checked that the ink cartridge was still sufficiently full, power cycled, no errors on restart.
Ran a strong cleaning and did a couple nozzle checks to no avail. Moved the print head into CR Maintence and removed the cover to take a photo and see if anything was blatantly amiss such as with the black subtank. Replaced the cover and it returned to standby position.
Shortly thereafter it threw the 085 Head Heat error, looking up online it shows that is usually a result of a short in the wiring to the print head. I found [this old forum] post pretty much outlining the exact beginning of my issue with no followup and a pretty grim outlook.
I have seen in other posts the suggestion to air-blow and re-seat the connections to the print-head, but I am unable to activate the CR maintenance as the system locks up with the error code shortly after initializing. Using the manual I am able to start the printer up and let it sit in Diagnosis Mode, but I do not see an option for moving the printhead and it remains locked in standby position otherwise.
Open to any suggestions on what I can do or if there is a way to release the print head from the locked standby that I could attempt to re-seat the wiring. Thanks for any thoughts.
Ssignature
Scott Steinecke
In diagnostics mode, go to the endurance menu and you can run the carriage back and forth. The head heat issue is often caused by ink getting in the connector to the head or the interconnect board. Usually the head has to be replaced. Check with Solvent Inkjet.
Umca
What is the problem with the head movement?
Just press the lock with your finger to unlock the carriage. You can move the carriage manually whenever you want, whether the printer is powered on or off.
Manual movement will not affect the drive electronics because the motor is separated by a relay.
The short allso may be inside the head (most possible).
Omega Plotting
I was able to get the print head to move out and took the cover off again, jiggled the wires a bit and moved the fans in the cover some manually, one of the fans did seem slow to turn but I possibly worked out a bit of grit that had built up on it?
I put the cover back in place and it initialized fine with no head heat error. I did a nozzle check and test print both printed out perfect, no issue with the black ink.
So far so good, like none of that happened at all. Unsure what the issue was/is for now, would it be possible that one of the fans was stuck and automatically throwing a heat error for preemptive safety? Doesn't really explain the lack of black printing initially, I will just be watching it for now.
factorywrapsco
Mutoh is known for issues like that...LOTS of issues! We dumped ours years ago. I have a great printer for sale.
Brand New Epson 64" SureColor S80600L – 10 Color Bulk Ink System
Never assembled. Never used. Still factory crated. Comes with Onyx Thrive RIP.
We purchased two for expansion but only have room for one more so this zero hour production printer is available.
✔ 64" large-format capability
✔ Bulk ink system (lower ink cost per sq. ft.)
✔ Premium wrap & signage quality
✔ 1-Year Epson warranty (ready to activate)
Skip dealer lead times and put this machine straight into revenue production.
Buyer responsible for shipping (can assist with coordination). It is in crate and on pallet.
$12,500.00 or fair offer.
Please call between 8 am - 9 pm PST. 951-314-1171 or 951-685-2222 (Office 9-5 pm) | Steve
Omega Plotting
Update on this as the machine had been working perfectly fine for a couple weeks but has now slipped back into the same problem but worse, now seemingly no longer printing both Black and Cyan ink. Followed the same procedure as last time just checking connections to the print head as best I can, but to no avail. Nozzle check very spotty for even the Magenta and Yellow that does print. Quick color bar image and result of test print shown below:
Omega Plotting
Left machine unplugged overnight, came back in this morning, powered it back on and its working fine. This all still likely pointing to electrical issues?
unmateria
Hi :) if its a 1604/1624, nah, something typical. Make a cleaning, check that ink is going to waste and look below the printhead... If there is a flood of ink on the printhead, just replace the wiper. If no ink going to the waste, replace the maintenance stationor try to adjust printhead height from the carriage assembly excéntrica nuts (2 white excentrical nuts)... Be very careful with those nuts :)
