Turbophein
After blowing my fuses on my Sp300, i was determined to have it back up and running asap without ordering new fuses. so after a quick plan i headed to the parts store.
Parts needed:
(4) speaker connector terminals. the heat shrink outside would be ideal.
3 ft of small gauge wire.
(2) Bussman panel fuse holders i got mine at west marine. (don't buy radio shack brand) http://www.westmarine.com/webapp/wc...oreNum=50523&subdeptNum=50549&classNum=50556#
package of 2A glass fuses
step bit and drill
soldering materials
phillips head to open the printer shell.
How to:
Open up back access panel
take your step bit and drill 2 holes in any location you prefer, this is the spot i found to work best and is easily accessible
mount the fuse holders
cut (4) pieces of appropriate length wire and solder/crimp a speaker terminal to one end of each wire.
assuming you know where the fuses are, clean them with q-tip and alcohol, start soldering the other ends of each wire onto the ends of the existing blown fuses metal tabs(the fuse can be removed but makes it harder)
then connect the terminals to the back of the fuse holders. almost done!
make sure to clean around the soldering area with a q-tip and alcohol before and especially after soldering to remove any flux residue if used.
install back panel
install fuses
power up and do a test print!
Parts needed:
step bit and drill
soldering materials
How to:
install back panel
install fuses
