heyskull
I am currently using Nazdar 203 inks (Their version of Roland MAX 3 inks).
If you see my previous posts I am having issues with the yellow ink which is I have been told by another ink supplier is caused by differences of surface tensions of the inks.
This is causing the ink to pool on certain colours which are using yellow.
The only way to reduce this is to print any designs with Reds in them at a higher quality. This helps but does not totaly eliminate the issues.
Has anyone had simlar issues with Nazdar 203 ink?
PM myself if that is OK.
Regards
Regards
