Need a Little more Ink
timkaz227
Need a little help w/ adjusting a profile. I printing onto Sihl TriSolv PostArt Paper(6 mil Semi Gloss) w/ a roland Versacamm SP-540V w/Versaworks RIP
The paper has a subtle texture to it and you will sometimes see a little paper showing where the ink coverage isn't complete. Kinda like when your painting a wall w/ a roller and don't get good coverage. Any suggestions on how to just "beef up" the ink just a little.
timkaz227
It only does 1 pass, so I looked at doing 2 passes. It double the the ink consumption shown on versaworks. Is that going to make the ink real heavy on the print?
timkaz227
Well, I tried 2 pass. It laid down so much ink it was almost pooling on the media. Any suggestions? Please help.
:thankyou:
timkaz227
You are right! The profile is printing 16 passes. What other things can I try? I don't usually mess w/ the profiles. Would increasing the max ink limit help the issue? Right now the percentages are75c, 100m, 100y, 80k w/ 200% max ink limit.
Jack Knight1979
don't touch the profile unless you know what you're doing.
in color settings change raster from colormetric to perpetual. That will increase the saturation. If you're there already, try a different profile, or write your own.
If you're working on a vector based image, change the vector setting.
