Need Help Folks
Blazingsun
Hey all,
Need some Help here Never been asked to do this
I need to qoute a corperation on doing 5 Semi Trailers with there ready to go logo. They have given me the Corporate Guide lines for ther logo which Im a little confused with I m waiting on a responce to what type of trailer they are flat or corrageted with or with out rivites.. My dead line for the quote is 2/15 any how heres the Info..
Logo size: According to there Guide lines
On a standard Platform Tarpaulins, The logo is not wider than two thirds of the length of the superstructure. Place the logo top right, observing the minimum clearance shown.
Get this there is no clearance shown?? Another question I asked them..
Colors:
Blue (RAL 5013 Cobalt Blue)
Red (Ral 3020 Traffix Red)
Now My questions to you guys is how do I match The colors in Vinyl second, Whats the going rate on something Like this?
ENTDesign
This is probably not much help: RAL is an Italian paint color specifier (paint chip chart), so you need a copy to compare the RAL color to your vinyl. It seems to me that someone asked about this in the last 6 - 9 months, so hopefully another member has a copy of the chart. I had one back in the late 90s at my previous job, and that came from one of our division's Italian employees.
The magic word tarpaulin suggests that they are describing one of the roll up soft sided trailers, not a box trailer. This might have material issues relative to adhesive compatability with the tarpaulin material, and it might be alot harder to apply than against a rigid sided trailer.
From what you posted above, it sounds like you would scale the graphic to 2/3 of the length of the trailer, but without reference to how near the top and left side of the trailer, you have to guess a little. Assuming flush to top and left side would give a maximum sq ft value, so scale the graphic to 2/3 trailer length to see how high that makes the graphic and calculate the square foot from there. Of course you need to know the trailer length.....
Good luck, hopefully someone else can help more
JMDigital
Dont know if this will help but I found a PDF of a RAL color chart from a podwer coating company.. Remember, this chart is most likely a close version of the color. Diffrent monitors and printers may re-create it diffrently but it may give you a start.
Good Luck!
  • ralcolors1.pdf
Si Allen
Piece of advice...walk away from this one!
Vinyl on these type of trailers (soft side tarp) DOES NOT WORK! They must be painted on the tarps. This is not banner material.
James Chrimes
I had a customer ask me to do one of these and I turned it down. And they wern't even close to wanting me to match pms colors. I knew that with cold weather the vinyl would crack all to heck. I only like doing jobs once. As big of a job as it was sometimes you walk away with more money in your pocket if you have nothing to do with it from the get go.
Blazingsun
I just heard from them They Trailer is Fiberglass with Rivets.. It is not these so called Tarpaulines.
As for the Colors they have given Me the Pantone Numbers.
and ther so called Guidline manual is outdated.. Go figure...
Dave Drane
Us old geezers know that Si, but you can't tell some of these young bucks. It happens a lot in my town and they think I am being smart, but they always end up getting their young paws burnt. I think it is a thing called experience. You only learn from your own mistakes.:Coffee: l
Don't take the job without actually seeing one of their trailers. Look at one that's already done. Take note of the size, colors, positioning, etc. and you'll have a much better idea of whether you can duplicate the work in a timely fashion. Also think about the equipment needed...everybody has a couple of ladders, but it's tough to lay vinyl on 2/3 of a semi trailer from a ladder. If you need to rent scaffolding, you'll need to build that into your quote. Will you be doing this work on-site out in the weather, or do you have a shop big enough for a semi? Try to think of everything before you quote a price on a job this big.
nodrenim
In job quoting, any item not checked will cost way more than estimated, causing the loss of the proverbial shirt. Get yourself some estimate check sheets and double check each and every item twice. Also make sure that all mold release wax has been cleaned off of the trailer body. To see one of these going down the highway with graphics flapping in the breeze is not a profitable sight.
