need help on background color
csc
Hey guys,
I'm having a little bit of a hard time in selecting a background color and need some help.
Theme supposed to be deep tropical. Customer wanted the colors you see.
Maybe a gradient fill of some kind? I'm stuck on this one.
CSC
Sorry, I pressed the submit key without the image.
csc
Thanks sign-man, I use PhotoPrint by scanvec. Can you tell me where the transparency tool is? Is some kind of filter?
csc
csc
I have the HP 9000s but the image was made in Scanvec Photoprint. Same as FlexiSign pro. Could not afford Flexisign so I settled for 1/2 price on the PHotoPrint which has the drivers for my printer.
csc
I'm going to make the lettering larger so to stand out better. Maybe I'll do a transparency for the background. Still hoping to get other color suggestions for the background not the leaves.
Jillbeans
Id make it a paler version of the lightest green in that busy background, then make it transparent.
To me, what the sign says is far more important than the background, and it's darn hard to read this.
The casual font in Natural clashes with the Papyrus, which in turn clashes with the Times Roman, and the red clashes with everything.
Stick to one font (Papyrus is not my fave but it will work here) bolden it up, change it to white, maybe try a dark blue panel across the whole shebang to put your most imprtant copy into (in white).
Not trying to be mean here.
Love....Jill
os101king
in addition to the above, that blue is basically like getting hit in the nose by a large fat man. and definitely no red on blue. whooo hooo. had a customer DEMAND red letters on his blue van. anyone else been forced (yes, at gunpoint) to do this? i had a freakin headache just from looking at it. only thing i can add is that that background image has a nice flow to it. try looking at the image from farther away and working with that flow.
poboy
Take Jill's advice & make your background transparent. I like your background but it is WAY too dominant.
This has a lot of potential. You're getting there. Good luck!
