Need help pricing 32ft x 5ft banner....?
vinylink0331
Hey, this banner will be 32ft x 5ft. It will be placed over vinyl siding. We have decided to screw 5 pieces of plywood to the vinyl & then apply the banner on top. This way we can avoid using ropes. We also we being applying plywood for the yellow banners. Also, we will be doing the front windows. We have decided not to digitally print it, so we will be using several different colors on the banners as you can see. Wanted to see if you guys had any advice on the price you would charge for this job. We have came up with a price, but I want to make sure I dont overcharge or undercharge. Any help will be greatly appreciated. We also will pressure washing the entire front of the building. Ball park price would be great so I can compare. Thanks!
S
SignTech
Guest
I don't know man I'd go digital. I would be around $1,000.00 for two colors max ..... just for the banner.
We charge $7.50 a square for vinyl ...... you have 175 square anything over 2 colors we go digital. Even if you came down to $5.00 a square that's around $900.00. But all the labor for using vinyl? Might not be worth it. Why not digital?
Pro Image
Just for the banner on 130z blue banner is 6.50 a sqft.............1040.00 but would discount it a little because of the other signs..........
What did you come up with.............???
I don't understand the plywood but it you screw into the siding to hold it up, The screws will hold the banner up as well.........
vinylink0331
We are not going digital because the banner is 5ft wide and we only have a 48 inch printer. We are using the plywood because the vinyl on the building doesnt run flush, so if we just screw the banner in it will make it wavy. Which i think could look bad. So with the plywood we will have a flat surface to work with & will not have to drill as many holes straigt into the vinyl siding. Our price on the banner alone was about $1062. 65. That is not including install. Does that sound a little high? We will be having to using so many different colors. Which was what he wanted. What do u thing for the install?
Pro Image
I wouldn't install it for less than 300.00 and he buys the plywood and all hard wear.........but I would throw in the other 2 banners as well for that price........
Doyle
your price sounds about right for digital, which in your case, I would sub out to one of the merchant members here, get it printed for $2.50-$3.50 sf and sell for $7 +/- sf
If I HAD to do cut vinyl on this, I would definitely tack on a $100-$150 for using so many colors, and for a 14oz cut vinyl banner like this, I would charge $1140, maybe a LITTLE less if it was a large order with other items.
Checkers
I would outsource the printing too. Simply put, less work and more profit.
The cost difference to make a vinyl lettered banner that big with that many colors versus another more durable substrate is almost negligent and I wouldn't hesitate charging double what you're thinking of charging.
The install will require a little extra effort, but you won't need stringers or anything to mount to.
Checkers
vinylink0331
No time for digital printing, gotta have done in 3 days.
Okay this is what we came up with. We are going to chage $3500.oo for everything in this attachment. This includes a 5ft x 32ft banner with multiple colors and outlines, (2) yellow banners that are 5ft x 6ft. This includes 8 pieces of plywood that banner will be attached to. Installation of the banners which will be on a roof. Installation of road side sign & windows. Road sign is about 30ft off the ground. Design time, material, & hardware will be included in this price as well as adding a basic one color layout to his truck. Does this price sound fair? Oh yeah, also we will be pressure washing. Thanks
vinylink0331
The banner is temporary, he is looking to open this weekend.
He is planning to back with channel letters in the future, but will not have time for that right now, That is why I believe he opted for the banner.
:help: I honestly don't understand what you're doing...... ??
You're gonna attach five- 5' x 8' plywood sheets to vinyl siding and then hang a banner on it and come out thinking this is less time, cost and less holes ??
Putting the banner up the way I pointed out the other day wouldn't take you very long. This method is going to create quite a few holes for a temporary backer.... and then you're gonna make more holes attaching the banner. You'll have five or six times as many holes to just putting the banner up on its own.
Your method will involve three people at least. Two up there working, whether it be from a bucket or off two ladders with a third guy on the ground. Lots of weight going on that siding. The banner method, alone.... would be one person in a bucket or one on a ladder and be done in about an hour or so.
vinylink0331
The way that you proposed Gino is great!
We left that decision up to the client, he decided that he liked the look better without the bungee's or ropes. So do you think that plywood is a bad idea, should we just scrath the plywood and just try drilling the banner straight into the vinyl, our only worry is that it will not look as good because the vinyl is not a flat surface & it will cause it to bow once we start drilling holes in it. Do u think that it would be fine to just drill the banner straight in? Maybe we will go up there and test a small piece just to check out how it looks.
As for the $3500.00, yeah that is for everything, should we go higher?
The roadside sign already has the substrate all we have to do is apply the vinyl.
vinylink0331
okay, we are starting to lean toward getting the big banner digitally printed.
Yeah would save a lot of time, Client is coming in first thing tomorrow morning. Once, we get the rest of our deposit, we might go ahead and get one of the merchant members to print it for us. That way we can be working on everything else that has to be done.
I would never screw a banner straight into a vinyl wall. You're bound to break and cause problems... if not now, down the road.
Also, the banner is going to flex and move around and eventually RELAX... a little at a time. You're straight in method will eventually sag big time. If a screw lets go, there goes your/his banner. You need to keep a banner taut and you can't possibly do that with a straight through installation. Either a cable or rope/bungee installation is good for this size banner. Had you said a 3’ x 8’ or something small, you can get away with your straight through install, but not with this gigantic sail on the wall.
:wink: Let me re-phrase that…. we would never do it. It’s not worth the chance of so many things going wrong and your being the professional here would have to fix anything that goes wrong and pay for any damages incurred while your installation failed.
Now, let me ask you this….. if you’re going to the trouble of putting up all of this plywood, why don’t you change it into lightweight dibond, save the cost of banner material and vinyl it and do a proper sign ??
Flame
amen bro. Just what I was going to say.
vinylink0331
Yeah we considered that.
We are going to run that past the client tomorrow & see if he is OK with that. Really the whole issue has been time, he wants everything fast, he seems to think that this is the best way to achieve it. I agree with you on these issues & now you have me worried, because I definately do not want this banner getting messed up & us having to go back and fix it. I would much rather do it right the first time.
ndemond
If I am wrong here let me know and I will have learned something new.
If your printer can make a 48" print why not just go with 48" x 32'. That way you can use your material wisely of diabond or alumilite (4x8 sheets) if it only prints 46 inches give it a 1" boarder all the way around.
Just a thought.
high impact
This is kinda crazy I think.
if you can print a 48" banner why are we messing around with all this extra headache for a temporary solution???
Print a 4 footer and attach with cables/bungees - it's temporary! The vinyl siding will NOT cause any ill effects for a temporary banner OR upsell into alumalite if he isn't sold on the channel letters later. If the customer is sold only on the five footer than have a MM print it, ship it asap and be done until channel letter day. woo hoo! ;-)
IF you are doing channel lettering later there is no way I'd go through the hassle of using plywood!
S
SignTech
Guest
The roadside sign looks 2 sided correct? What's the size? Looks like 4' x 5 or 6 wide? Is the current face re-usable? In other words what's on it? Do you have to remove vinly? Id there fading ......? Looks pretty high up ........
Are they taking the faces down for you to apply vinyl in shop?
Say they are 20 Square feet we would be at $25-35/square including translucent 2 color and install. Around $600.00 a side plus the banner, tons of labor putting up all that ply, heights ........ etc ... $3500.00 might cut everything ... just take your time and go slow ...... customers like to rush you ... not giving you time to think out the actual end of the day cost.
Doyle
I second the motion to not drill a bunch of holes for the plywood backer. Sell him up to alumalite or use bungees.
