need help quoting this job
Erin
Hello everyone.
I need to quote on doing a 2' x 8' sign that will be put up inside an office on the wall. The sign will have the company name and a logo on it and will be done with blue vinyl.
I'm still not sure what I'm going to do the sign on as far as the substrate goes but based on what was suggested in my other post I am thinking either PVC, Acrylic or Sintra.
I have never done a sign like this using any of those substrates so I would really appreciate knowing what some of you would charge for doing a sign like this on each of those substrates...
Thanks!
kalvix
I'll be somewhere around $200-$250 depending on the complexity of the vinyl. You could add some dimensional letters to make it really pop say routed out of 1/4 pvc or aluminum faced pvc...
Marlene
Erin, have you decided on a mark-up for your materials yet? If not, take time and come up with one as it will save you time and cut down on pricing errors for you. If you aren't sure how to come up with a mark-up, you might want to purchase a pricing software and plug in all the info it needs to help you quote. Our company has a set mark-up so all I need to do is know the price I pay, mark it up, add in labor and I'm consistant when pricing. Asking what others charge isn't a great way to decide on what you will charge as there are too many factors that go into pricing. Knowing what others charge should only be used as a guide.
Erin
ok, thanks Marlene. How do you figure out what your mark up will be? When doing something like this that is 2'x8' and you have to purchase the material in a sheet that is 4'x8' do you mark up the price of the entire sheet even though they are only using 2' of it?
Checkers
Hiya Erin,
IMHO if it's a substrate or material that you consider stock or will use on a regular basis I would only charge for the amount used. However, a special order item, such as an unusual color or material, I will charge the client for whatever I have to purchase, including mark up.
It sounds like you creating a fairly simple product. So, the easiest way to figure a price on something like this is to, in your head, walk through the entire process of making the sign.
First, you have to recreate the design. Depending on the complexity of the logo, it can take anywhere from 15 minutes to several hours.
Second would be the approval process. If you nail the design on the first try and the client loves it, you're golden :) If not, you'll have to charge for revisions too.
Third production - how long will it take you to strip & clean the substrate; cut, weed, tape and apply the graphic(s) and wrap the sign up for safe transportation to the job site.
Then comes the installation. I normally charge per mile to get to the job and figure at least 1 hour on site. Depending on the complexity of the job, it may take more or less time.
Now that you know how long it will take and what to charge for your time, you need to figure the cost of your materials. If you thought the process through completely, this part should be easy. Just make a list of everything you used to make and install the sign and add your mark up to it. I normally mark up vinyl and special order items 200% and most other materials 40%-60%. And don't forget to charge for your mounting hardware.
Sales and invoicing time, such as quoting and meeting with the client is built into my overhead. So are my consumables - things like rags, cleaners, Xacto blades, Stabilos, etc.
Anyway a project like this could be worth several thousand dollars because it will represent the company. At a minimum, from what you're describing, I would ballpark it at just under $1000. But I would upgrade it a little making it look more like this...
The above image is all acrylic with laser cut and pms matched and painted acrylic. It is mounted to the wall using stand offs. It would probably retail for around $1500.
A similar, full blown version is this...
Here's a link to my former employers website showing pictures of several items we did for the client...
http://www.purpose1.com/energy/7.cfm
Checkers
Geary
...... I am thinking either PVC, Acrylic or Sintra.
Erin,
Just a suggestion ....since you know that you are going to just use vinyl lettering on one of these very common substrates..... has anyone ever suggested to you to get a "Signwriter's Guide To Pricing" or The SignCraft Pricing Guide ? I have found these to be very useful along with some estimating software I own called "EstiMate".
Okay, on pricing that I would charge for this:
First off Sintra is made from PVC....so it's the same thing....and I would charge about $300 for the sign based on a one-color "simple" design/layout.
On acrylic: 1/4" material - $400. 3/8" material - $500.
Installation: $150 for the install (includes fasteners) plus a trip charge ($1.50/mile)
~Gear
Erin
Thanks for all the info Checkers and Geary. I did look into picking up Estimate but I just don't have the money for it right now. I know it is more than worth it but the money just isn't there right now. Do you know where I could purchase The SignCraft Pricing Guide or the Signwriter's Guide To Pricing?
Si Allen
And if you are not subscribing to SignCraft, you are handicapping yourself!
Scrape up your pennies and subscribe to it! It is the best of the best in trade magazines. Everyone who has been in this biz, looks forward to each and every issue!
