I keep having a issue with my print. I currently use flexi complete and hp latex 315. Here is the issue I have.. if you are technician I will greatly appreciate your help.
6.0 mil perforated high performance vinyl film with a white print side and a black see through side coated with a clear low tack repositionable removable solvent acrylic pressure sensitive adhesive designed for exterior/outside mounted one-way view-through window graphics. The vinyl will accept a variety of wide format digital printing inks including solvent, eco-solvent, UV and Latex. The dual lay flat liner construction, perforated/solid liner, offers good dimensional stability in a variety of ambient conditions and is cross compatible with wide- format digital inkjet printer platforms including UV. The adhesive is designed to cleanly remove from glass with little to no adhesive residue.
Product Description
Product (Type): Calendar Vinyl (PVC) Perforated Window Vinyl Film
Hole Pattern: 60/40 (60% Printable Space, 40% Non-Printable
dannyd1962
Remote Freelancer
I'm thinking its an issue with the material not laying flat while its being printed. Make sure your take-up reel is staying tight. To me it looks like those 2 may be the underlying issues.
Stacey K
I like making signs
I have the same printer. I've had bad luck printing on window perf, I always get tunneling.
Signstein
Vacuum settings maybe? I get prints like this on paper when the vacuum is too high and it doesn't feed through properly. Does window perf behave differently due to having lots of holes? Like maybe its lighter and is held more strongly by the vacuum?
dtfonestop
Looking at your settings screenshot, I'd check the media advance first. Automatic tracking (OMAS) is on, and that sensor watches the media surface to measure how far it moves. On perf it's looking at a field of holes, so it can misread the advance, and that gives you exactly those light bands across the print. Try turning automatic tracking off for this media, run the substrate advance calibration on a scrap of the perf, and save it to the preset.
Quick way to rule out the heads: print the same file on plain white vinyl. If that comes out clean, it's the perf handling, not nozzles or alignment.
Does it band the same way on regular vinyl, or only on the perf?
  • Agree
Reactions: 1 user
