I just got back from meeting with a potenial new client. I hope I can explain this properly. They want a sign like what you see at construction sites, you know how you can see them when you are coming from either direction down the street? I've attached a drawing (I know it's a pathetic drawing) that might give you a better idea of what I am talking about.
Anyays, as you can see (hopefully) there would be 3 posts in the ground and 2 sheets of plywood (is plywood what I should use for this)? The plywood would also need to be painted yellow and the text would be in black.
I have a couple of questions. Is plywood what I should use for the actual signs? What kind of paint should I use to paint the wood yellow? And how do I go about pricing the entire job? What would I charge for installation? I've never done a job like this before...any help would be appreciated as I really don't know where to start.
