Felix Sepulveda
Hi All, finally I decided to buy an Epson S30 almost two months ago. This is my first Ecosolvent printer. I'm still getting to know the machine. Sometimes I get drops of ink during printing (specially magenta and yellow). I'm in the Dominican Republic and Epson has more or less good service here. My dampers were changed by Epson, but I still get the problem sometimes. It almost always occur when an ink cart is low on ink. The technician told me that maybe when the ink pressure is low the ink lines might get bubbles. Has this happened to any of the Surecolor owners here? should I request another damper change ? or it might be an head issue ?
Certainly if a do a low level cleaning and put a new cart in the almost empty color, the problem goes away...... but of course I can't accept this as a normal procedure.
Thanks for your help.
I'll give it a shot on the next run. Another question for you Snydo... Do you have any issues with panel alignment on tiled jobs? I have run into an issue and the only way to resolve it is to not use the take up reel. It makes no difference which vinyl I run or heat settings either. It seems that the take up reel pulls at different amounts depending on how much is on the feed roll? (weight of intake material?)
Also put it on the 6000 and had no issues at all. ( ruled out the file as a problem)
