new (first) logo for my fledgling company.
ZOMBIE_05
Just curious folks, What do you think? I like it my wife likes it and I think it would look quite decent on my truck or van window. any opinions? I'd love to hear (see) them.
2972renfro
1. the middle of the Schultz letters are knocked out so that the oval behind shows through - doesn't look right. Make them white instead
2. too many chrome highlights and the chrome horizon line on the D does not line up with the "esigns" part. Also if Schultz was actually made of chrome, the horizon line would not be perfectly straight here. The letter style is made to look 3d with the facets, so the line would not look this way, but rather follow the contours of the letterforms
3. consider using a font other than Brush script - it is overused
juniorcdn
Your logo looks a lot like mine. Another member "Doug" came up with the layout. Even the same prismatic fonts were used.
I sure hope you are not in my part of Canada. I live in alberta.
ZOMBIE_05
hmmm
jr cnc, I hadn't seen your logo there b4. But now that I have, I believe that I'll have to do the right thing and change it. It's unfortunate being that this is the only one in about ten that my wife had liked. As for the same font, I've used this chiselled font on everything that i was allowed to. I just really enjoy the look of it, not just blocky. By the way, where in Alberta are you from?
Kevin
James Chrimes
The Fonts Are Not The Same But The Styles Will Be Similar For Many New Designers. Often People Think Because They Are In The Design Business That They Need All Of This Crazy Movement And Color All Over The Place. Time Will Teach You That A Good Design Gets Right To The Point. If You Want Fancy Letters Invest In A Good Font Collection And Spend Time Creating Some Of Your Own. Good Designs Are Not Often Just Typed Out On The Keyboard. Here Is A Simplified Version Of Your Design In Black And White.
iSign
Zombie, I agree with the other comments & although I like it I think you could make a few rounds of adjustments & come up with variations that both you & your wife will like even better. I thoight the gradient fill running through the word Shultz was unique & even though the straight lines on it would flow up & over the dimensional prismatic depth if they were truly 3D letters... it still doesn't bother me... but I don't like where white shows through at each end when Shultz runs out of the oval. I think it's great that you go out of the oval, but put you fill in there. Then lose the fill & the brush script in Design & lose the fill in the outer oval as well... maybe just white with a thin black outline to define it. I also done like the curved lettering. I usually like the vertical axis of the letters to adjust with the curve rather then staying vertical. I would also look at keeping down to 2 fonts. Maybe treat Designs the same as Shultz, but use a nicer script for the custom decals & logos.
Hey, nice job Jr CNC! I never saw your final version. I'm honored that you liked my starting place & glad to see you put together your own version of it.
Fred Weiss
I think you should put the horse before the cart. Take your idea and reduce to to black and white and make any changes so that it works well at that level. Next work with it by applying solid colors with no special effects. Then finally add special effects like chrome effects or gradients.
At each point working from simple to complex you will more easily see what may need improvement. What you are showing here at this time is so overwhelmed with effects that it gets in the way of appreciating the design as well as it being able to quickly communicate with the viewer.
juniorcdn
I really like SIGN SOLUTIONS version of the logo.
I think the hardest job in this venture is creating a logo for yourself. Customer logos come and go but you have to live and like your own for as long as you are in business or decide to change it (Costly Venture). Your logo will be incorporated on your invoices, business cards, web site and advertising. It has to be what you personally like and something that attracts your clients.
This is truly the best forum out there with all the best people.
ZOMBIE_05
my logo
Thanks for all of the comments folks. As far as the chrome type gradient goes, It's just there to show where the chrome polyester would be used so I wasn't too concerned with the lines running through it lining up. If I was to get it printed, I would have put some more effort into grouping everything b4 adding the gradient to keep it uniform. As far as criticism goes, keep it coming. I really appreciate the opportunity to learn from others that have more experience in the field.
Steve C.
Just because your logo is in an oval and has a chiseled font, You should not need to feel that it is too close to the CNC logo. Stick with what you like taking into consideration some of the very good suggestions here. I think the work Design should be a solid contrasting color, here's my take.
iSign
nice work Steve.
I agree both logos with ovals & chiseled fonts are different enough & will also be seen in numerous other logos.
