dtfonestop
That's a good catch with the Atlanta tech. If the levers and cams that hold the head down aren't the same as on a standard Plus, they may not be pressing the head down evenly, and a head that sits even a hair off would fit a streak that lands in the same spot every pass right at the overlap. Whether you end up swapping those parts or just reseating the head, a few things help make it a one-time job:
1. Before you pull it, take a photo or put a fine mark where the head plate sits now, so you can see afterwards whether it moved.
2. Clean both mating surfaces, the underside of the head plate and the seat in the carriage, with a lint-free swab and a little cleaning solution that doesn't leave residue. Look for dried ink, a tiny fleck of debris, a burr or a scratch like netsol said. Even a little crust under one edge tilts the head enough to show as a fine line in 2-head mode.
3. Make sure the head cable isn't pushing up on the head as it goes back in, and that it's fully seated and not creased.
4. If the lever and cam parts get replaced, check that the lever closes fully and feels the same on both sides before you tighten anything.
5. Let the head sit flat on its own first, then snug the two screws a little at a time, alternating between them, instead of fully tightening one and then the other. That keeps it from rocking or creeping as it tightens. Snug is enough, don't crank them.
6. Then yes, redo the alignments, in order: slant and stagger first, then head-to-head position, then drop position for every resolution you actually use, then feed compensation with both heads running.
One quick check once it's back together: look at both heads from the front at eye level with a flashlight. If one sits even a hair lower or higher than the other, or is tipped, you'll usually see it right there. You're close, that last little line is almost always something mechanical like this.
