New JV300 Head streaking Mimaki guy says head is out of whack too high or something ? Ever heard of that
tooserious
I put a new head in my Mimaki JV300 Plus and 1 head looks good 2 together is terrible no 2 head looks streaked . Any suggestions. I paid a guy to come calibrate the mechanical part. He says he did but a Mimaki Tech said its off ??
Smoke_Jaguar
Check your head height and media guides. Make sure there's not gunk built up on the guides or the platen. Most common cause of that issue.
dtfonestop
If the guides and platen are clean and it still streaks only in 2-head mode, that pattern usually means the new head isn't sitting quite the same as the other one. One head on its own can look perfect even if it's a hair high or slightly slanted, but once both heads share the pass, any difference in height or angle shows up as streaks.
That fits what the Mimaki tech told you. I'd ask whoever does the mechanical work to check the new head's height and slant against the other head specifically, then redo the head-to-head position and drop position adjustments afterwards, since those were set for the old head.
Did the streaks show up right after the head swap?
tooserious
What kind of streaks? Have any pictures?
I think it has been narrowed down to stagger now . I had a company come and say they calibrated the heads and set the drop pos in Service mode but only 720 and 1440.
They would not return and said it was ink starvation probably. Now it prints good in both heads but if I use together little streak probably 1/8 of inch or less . I have a JV300 Plus and it has Head Check in service mode and the 3 rd one shows overlapping heads (darker lines in between) In have no idea what the 4 tests are 0-3 because no one has a Plus manual.
tooserious
Definitely check and do the head slant and stagger adjustments
We have done those over and over. Used a scope to get adjusting 34, then we redid stagger . Thought we were right on the money. When I do a print of head check both are good but I think one head stilll is overlapping but in stagger adjust it looks perfect????
Smoke_Jaguar
Corrupted rank code can cause similar stuff to happen as well, some sketchy heads will have a chip with the wrong code and it can cause that.
Inkjetparts
does the streak land in the same spot every pass right where the two heads overlap? if its always at the overlap thats head to head position/stagger, not ink starvation. if it moves around, run a nozzle check right after a long print and look close at the new head, lines dropping out there would point at feed not alignment
dtfonestop
Thanks for posting the pictures, they help a lot. If each head prints clean on its own and the streak only shows up when both heads share the pass, that points to the two heads not lining up with each other rather than ink starvation. Starvation usually looks like dropouts that get worse over a long fill, and you'd normally see it in single-head mode too. That darker line where the heads overlap on the head check is the same story.
The order I'd work through it:
1. Head-to-head position first. In service mode, adjust the position between the heads (both in the feed direction and across the carriage) until the overlap pattern prints even, with no darker or lighter band where the two heads meet. That dark overlap line is the thing to chase until it disappears.
2. Then redo drop position for every resolution and pass count you actually print with, not just 720 and 1440. Each mode keeps its own value, so if you run 540 or 1080 or a high-speed mode, a mode that was never adjusted can show exactly this kind of fine streak.
3. After that, run media feed compensation with both heads active, on the media you use most. A tiny feed error shows up more in 2-head mode because each head is laying down part of the band.
4. If the head-to-head adjustment runs out of range or never quite lines up, the new head is probably sitting a hair high or slightly slanted in the carriage. That has to be set mechanically against the other head first, otherwise the electrical adjustments are just chasing it.
One quick way to tell which one you're dealing with: if the streak repeats at the same spacing all the way down the print, it's feed or head-to-head position. If it wanders around, it's more likely nozzles. Hope that gets you over the line, that last 1/8" is always the most annoying part.
tooserious
Yes it lands in same place small almost looks like feed correction but that is perfect
tooserious
Could the head I installed not be sitting down right for some reason?
netsol
we all know you should clean the mating surface the hit sits on, but how often do we really do that?
probably time to pull the head and be sure that surface is completely clean
tooserious
Mine is the only JV300 Plus with Plastic levers and cams in one piece. i argued with 2 Mimaki techs and then when I sent Atlanta the pictures he said I'll be danged ...
Inkjetparts
same spot every pass with feed dialed in pretty much points at the head to head position, so you're on the right track resetting it. once its back in redo head alignment and drop position before you judge it, and check the nozzle check right after so you know the new head is firing clean
  • Agree
Reactions: 1 user
