New to Vinyl Sign pricing - Need Advice
Ogriv
Greetings,
I just received my first large sign order. I have designed a sign that will fit on a 4 foot x 8 foot substrate as the customer has requested. There will be 14 letters, each being 12 inch x 8.5 inch in size. There is also a small amount of text to the sides of the large print. My software indicates that this sign will use 30 square feet of vinyl. I will be using Oracal 851 Premium Cast. I will be installing the vinyl.
I have only had my cutter for a week, and have only been doing little decals and such. I realize that vinyl signs are not priced by material, but more on the market value. Any advice would be greatly appreciated.
jimdes
For starters, you're correct about not charging by material costs but by market value. Take into consideration a few things though. You are new to this, this is your first large application and honestly, you won't be able to cover all your bases no matter how thorough you are.
30 feet seems a little liberal for material estimates, but that's minor. If the customer is supplying the substrate, I'd say around $225 if you have to provide the substrate, add material costs X3 (minimum). All this of course is assuming you have minimal design time in this and it's straight forward text.
ST Media has a good book about estimating and pricing signs at: http://www.stmediagroup.com/st-bin/quikstore.cgi?product=xx9 you will also see Chris Adcock has the "SignCalc" spreadsheet and there are several software packages for estimating your signs.
Take your time, learn the biz and get a lot of good books. If you undercut other sign companies, there's no doubt that you're undercutting yourself. By charging too little, you'll never realize the rewards of operating a sign biz with adequate tools, software, fonts and artwork. All of these things make life a lot easier and business more prosperous. just look at my tag line . . . you can tell my motto when it comes to pricing.
Ogriv
Thanks, I'll check out those pricing resources. The text is straight forward, no layering or shadows, just large. I under estimated the apparent retail cost, I have not given a price to the customer yet, because I feared I was too low. I have a few days before he wants the total cost, so I have time to work on it.
OldPaint
try this by the sq.ft. calendered vinyl if you cut, weed and tape $4 sq.ft. HP vinyl same as last...$10 sq. ft. now if customer provides a substraight you can just apply the vinly to and you put it on 1 side of 4x8, HP VINYL, WOULD BE HIGH END $320.00 low end $256.00. if you did same 4x8 with intermediate vinyl high end is $250.00 low end $180.00.
pricing by sq ft is simplest method. all signs you will do will have X sq. ft. so dont ever sell you vinly for less then $4.00 for R.T.A. (ready to apply).
if you buy the substraight(board/alum/coro/alumilite you need to then figure your time into getting the material, the price of the material and add no less the 20% of what material cost you back to its price...so you can make money .
signguy95
I don't know the market there in ohio but here in alabama it's set pretty low...For basic lettering (meaning I just type in the letters, pick the font, and size to the sign) I charge $3.00 per sq. ft. per side. If I have to spend extra time designing the I charge my regular design fee of $30 per hour. I regularly use Avery A6 and that's what I am pricing...It calculates to $96, so I usually round to $100...Always round up! :Big Laugh On the substrate (just so you know later) I charge a 45%-50% markup plus any shipping charges.
OldPaint
iam 5 miles from the alabama border...and if you sell for less the $4 a sq.ft. ........you might as well bee workin at wendy's!!!!! all you gatta do is stick to your price and you will get it. at $3 a sq. ft. it dont give you any money/incentive to do this work......i get paid for what i do.
Fred Weiss
There are lots of potential clients who will not buy from you if you are priced too low. There are also lots of clients who will only buy from you if you price too low.
Which client do you prefer to cultivate?
Here's how I would price this sign:
1. Figure the sign as if you were supplying everything. In my market a straight text on aluminum using HP vinyl would go for $10 to $15 a square foot. Let's take the middle figure. 12.50 x 32 = $400.
2. Customer supplied substrate .... subtract out what the substrate would cost you without any markup. Let's say $75.00.
3. $400 - $75 = $325
If you feel it's too high then go with the lower end of $10 a foot. $320 - $75 = $245
The client isn't buying a commodity .... he's buying a sign created by Ogriv. He just happens to be supplying the substrate.
theroq
I agree with Fred, if I were making this sign I would do it this way then adjust alittle if I think it were too low or too high.
