Nifty trick to install horizontal panels on wall
Texas_Signmaker
Very Active Signmaker
Normally I panel vertical, but on corrugated metal buildings, vertical can be tricky because there is very little room on the ridges. When I do horizontal, I came up with an easy trick to line the panels up in seconds. I use a metal bracket and fasten it to the top of the bottom panel where I would normally pop a screw in anyway. It creates a little pocket for the top panel to slide in and sit right on top of the bottom panel. It also keeps it in place until I can get some screws in. This also works on 8'x8' real estate / construction site signs.
MtjUmxAbp3Q37opkSt_YSlJZjjKTKngFvc72GlVsGRQTGDs8tZY6EXa5pTiqYrnnRDaKOvKvtDm8JSqnM4wizdJFDXoK135bxiTSjVuifCr6iWb8ub89XusUPgvhEwMXZL4nTaAThrE=w1920-h934-no
-qRxzmb015Lch9FZdyCzzHPQjFm1bXQGD28afBtCh5I8s8NDV1SR61_a8vRSAj3aUWtEeOk0DU2yFm_ObSC3cGEUNE5itXqZQVNe52MHq8YORfEkNAi7AuclbjjAjLfHe6mFx-GRafY=w1920-h934-no
dBK3278iz4RvszNM4muFHC21kGnud4XSEa-7HWAi89bMKd8DYy-qU3U8IOtHmMfJclJJrH1CBCGJIfJRnQhx1YKlHieVo_BgTxXzy7GVSaP5hSl0ZE9_u7MqUlqeWUipF1_JsZal6eCPYymm3egDl4Mw58dL6ZcFhfQrMj305P2Moi5WxLc45JGHSQrL_wJP6QEErRj8Ad8F5UsQmn51HFoyb8PMlt7-JtIv_SxDEmlvjiRdhSEIK2ZsxMY49GQrrZWuIw2pkFj1PmUCizX6VVhrwmB7qVUvpNinwtqKUd_tiLtikKn7sCKsH-ivpNNarXXFArIo1Zl6T3kXyOsmuq3Hcy0K0garU4GksRA9FCrZn8mJPDAZS2MLqPNe9EQ67rhvAd2OeOLXvxugKlCKx6rnd3xgvlOvuCnPGabMITAVp0O44N99ergDCBFBxN1yYTUp__kXrUo5TbKWlUeGc4cTTImzXdnSeYGImPl16gN_GA5HcBirKpfA9d3GnjGbd4jRUhrVMIWK8uglMmIbC-MqV1Xg64U5VlnGNYHiT9Ks0iea7hPFW5N1zu9lAy6Y6MerX_JTqd9rJIOhr4-6Q5LhGskd2UWtrogCGeooVvOQgoGu1UZ_36th3_JDNVxc8BZoalslRJjYJReB0qWhma5SeI-CBh0ruAraY4vQDXXInZmnWP5E4lpSW-c2xwrhPEzuGmaIXxXyEpYjs9HehfoexQ=w1920-h934-no
Reactions: 13 users
Texas_Signmaker
I do something similar on horizontal seems. I have a piece of angle we have reused several times now that's 20' long 2x2x1/8" architectural style (Square inside corner) Screw it to the bottom of a cabinet like a piece of trim, or turn it 90 and screw it to a wall for a wall sign. Plus it's easy to level.
I like this though, never thought to panel vertically on corrugated walls.
I'll say if you like c-clamps, check out kant-twist clamps. Their more robust, and they have a wider clamping area so you can lift more weight without marring the materials as much.
I'll look into those.
The C clamps are handy dandy... I'll put a couple on slide-out poly faces when they won't budge, or clamp them to the top of a sign when I need to lift it.. so much easier then pinching it with my hands.
