Now Processing Error
Kipp
Hello! Been having this issue off and on for a long time and can't figure it out.
Running a Versacamm 300 and it freezes in the middle of print jobs only, reads: Now Processing, and I have to shut down the printer.
I run an ethernet cable from the printer to my modem, then to my computer. Only started happening when I upgraded to the newest xfinity wifi modem.
I appreciate any help! This is soooo frustrating!
It's most likely a network issue. Cut files are only a few kilobytes so the printer can store the entire file in memory. Print files I huge in comparison so the printer relies on the computer to keep feeding it data as it prints. My first guess is that the IP address for the printer isn't reserved in the router and so another device is being assigned the IP address causing a conflict. Try connecting directly to the printer without the router. If it works fine, you can rule out he printer and the computer as the problem.
netsol
Solvent inkjet,
If I were guessing one of the windows upfdates put the checKmark bavk onthe power management tab for the lancard of the pic. The one that say "allow windows to turn off this device to save power"
Go to device manager to check
