Omega 2.02 Pulling my hair out!!!!
sportycliff
What am I missing?
Can't get it to import or open anything that works, BMP,JPEG,TIFF
It opens to a low res thumbnail. Then when sent to GSP plot I get a "No shapes found in file" error? HELP!!!!!!!!!!
It has to be something stupid?:banghead:
Tony Teveris
Import the image, select it, go to the Fill Image dialog and select a higher resolution. It also sounds like your default is set to "template" for the image so also select either Spot or Process color in the same Fill Image dialog.
sportycliff
Thanks Tony!
That seems to have done the trick, but I'm curious how does this affect the "no shape found" error?
sportycliff
Was just trying to see how it would output. Selected it and tried to send it (all). Must have been set to template as Tony said. Tried it again the other day and it worked fine?
