Omega foil adjust test print
JRgraphics
Hi, I've been trying to print the foil adjust test pattern in Omega 5.0 to the Edge LE. I keep getting Data Error, does it work on the LE? :thankyou:
Tony Teveris
It use to work but we updated and made changes for 5.0 - do you have all the 5.0 updates - Check for Updates from Composer, GspTray, etc you should be at 5.0.0.40 as your Omega version. I'll look into it.
Tony Teveris
Ok I've confirmed there is a bug going to the Edge I and will be addressed in the next update (Build 41). JR if you email me I can send you a file as loang as you are up to date with the latest Omega 5.0 updates which would be Build 40.
