Onyx 24 issue BEWARE!
ikarasu
The sad part is, Onyx will fix these issues in their next major release... And expect their customers to pay to get the bug fixes. Just like the previous versions.
Hah... Good luck! It Took 2 major releases for my bug.
I had an issue since onyx 21.
If you had a cut file where you added bleed via onyx.... It would cut off by however much bleed you added. Or if you added bleed then automatically added cut marks it'd do the same thing.
I emailed them... Took me a few back and fourths and they were able to replicate it. Did it on every printer, every cutter.
My first email and then confirming it's a bug was Nov 2021.
I got an email on Dec of 2023 saying my logged issue was now fixed in the newest release.
I asked if there would be a bug fix or patch for onyx because nothing in onyx 23 was worth me paying 1.5k to upgrade for.... And they said no. I asked for a discount or something because it's dumb that it took 2 years to fix a bug that severely affected my workflow (it did, I had to completely change how I was doing wall panels because of it), and got an offer of 5% off or something so miniscule for upgrading due to being a loyal customer and helping them point out bugs :rolleyes:
I paid and upgraded... I usually pay and upgrade right before a release to stay current, but it was insane that they can put a major bug fix behind an upgrade like that.
Hopefully this bug doesn't take 2 years to fix, and doesn't come at a cost to fix! Paying so much money for software, especially on a yearly basis should.get you quicker bug fixes IMO... The whole point of the "subscription" is so they can continue to improve the software with the money they get.
I'm fine with monthly subs, even fine with insanely priced software, I just wish it came with insanely good / fast support to make it worth while.
Reactions: 1 users
CanuckSigns
We were told that subscription software would allow the developers to put out patches and updates more frequently and not have to wait for major updates, but this is not the case with onyx.
Subscription software is horrible for the consumer, there is no incentive for the software companies to innovate or provide good customer service, you are stuck paying them every month, they are thriving on your sunk cost fallacy. It was always just a way to provide a steady income stream for software companies who used to have to innovate and update their products in order to get paid.
White Haus
Not a Newbie
I thought about that and tried that. However it wasn't nesting, or at least it would not rotate to make use of most of the media... Print is individual jobs was taking up an extra 30 ft of material.
Print individual is how I do a lot of stuff at work on our solvent printer because it doesn't make a difference, on a latex printer it's still spins down the heater and has to reheat itself up for 3 minutes.,. Still better than hitting Print 30 times, but but I'm not willing to waste an additional 30 ft of material on a 90 foot print.
Turns on I never uninstalled Onyx 22.5... so I had to do is open it up and I was good to go!
Damn, was worth a shot/mention!
ONYXtechtips
Onyx has released a Micro-Update in regards to some of the cutting issues you have been experiencing in this thread. You can use the links from our website to download. Download the latest version and when installing, select the repair/upgrade and the software will update. Release notes are as follows:
• Resolved an issue where jobs would not group together when using XY Trimmers if image dimensions were different.
• If a print job had multiple sheets and had a cutter on the job, not all cut files were being made. When multiple cut files would work accordingly, they had the same barcode. Both issues have been resolved in this update.
• 10.1 RMS license server could be installed on one computer but not on anther network computer. RMS license server is now working accordingly.
• The “vertical alignment” checkbox for Fotoba and XLA is now able to be toggled.
• Print event messages for nest and print states had print failures that would occur when using SRM key with Print Width set to 24’’. Multiple images can now be printed if within print width maximum.
  • First Place
Reactions: 1 users
ONYXtechtips
Since we're fixing bugs... I've had a bug since onyx 22 thats still there in 24... On The Epson resin printer, if you load a media and then click get media info / size, onyx will crash. Then when you re-open it... itll get it perfectly fine without crashing.
Happens every single media load unless you wait like 5 mins after loading to update the media... I never submitted a case or reached out, just figured it'd be fixed eventually... It's more of an annoyance since all I have to do is re-open onyx, so it doesnt "break" anything, but its been almost a year.... And I confirmed it does it on 2 different computers, and it doesn't do it on the latex or solvent, just the Epson r5070
It would be very helpful to contact our technical support team and point out issues that you experience. If we are unaware that a problem is there, we could not fix it.
ikarasu
Just wanted to confirm the issue is fixed for me. Sent 2 2 FT Tiles... It didn't create the cut file for the second until it started to print it, Where as before as soon as I hit print it'd generate every cut file, so at first I was worried it wasn't working, but it seems to be fine!
Reactions: 1 users
White Haus
Not a Newbie
Good to know, thanks for reporting back!
Goatshaver
Good to know that some of those cutting issues are now resolved. I'm still going to wait, hoping there will be an update to support the UCJV330 like they had told me when I went to buy 22.5, guess integrating that machine didn't go as planned.
ONYXtechtips
We do have drivers for the Mimaki UCJV330 with the latest release on Sept. 20. This release also includes the ink layering abilities in the media profile settings.
Goatshaver
Thanks for letting me know about this! I had just looked up supported printers on the website and it wasn't listed. I'll have to check it out!
MNT_Printhead
No longer working among the Corporate Lizards!
The one I speak to doesn't listen and talks over me. I have only once had an issue resolved with phone support and that was about 5 years ago. When he sent his summary email he said my issue was with 22.5 when the call originated from an issue with 24, but to be fair both are having issues and I mentioned them. I am about to give up and go back to 19 until 25 is released.
White Haus
Not a Newbie
CanuckSigns
Pauly
Printrade.com.au
The fact it took 3 or so months for issues like this resolved is very poor. This would be a result of lack of beta testing and listening to customer feedback.
This is literally why we moved to caldera. I haven't had any bugs as such at all from any update. And if there was, it's fixed with in days, not months.
You guys need to take this comment, pin it in the office and evaluate why these issues are happening.
Reactions: 1 users
Caren Hines
Yeah I already found this out after I printed 1/4 of a roll. If you print the sheets one at a time it gave them individual barcodes, if you queued up multiples, they all got the same barcode. I also noticed that my Graphtec FC9000 was not handling jobs correct and doing a cross cut at the leading edge of the sheet instead of the back and I had to manually cut. Also seemed to lose connection after I ran a cut and I had to restart the cutter and the cut server.
They also still don't support the UCJV330 machines in the v24 update. :(
I spoke to them about it a couple weeks ago and it was escalated up to engineering but I have yet to hear anything back.
Glad I didn't uninstall v22.5.
I have had issues (escalated) up to the engineering department too. I've never received any response or updates on the issues either. It's their way to get you off the phone because they have no answers!
Reactions: 2 users
ikarasu
Well... I just ran into the issue again, not fun!
It works fine for my graphtec. but I just printed 4x 150 FT banner rolls using the multiple sheets option for cutting out on my summa Flatbed... It'll send the data over to onyx fine, it'll read the first front marks...goto the second mark, read it, then try to read it again and say that marks already been read... Click skip... itll goto the next mark, itll read it...then try to read it again and then say the marks already been read.
I can't say for sure its because of the multiple sheets, but every other cut file I've sent has worked fine.... this is the first time I've experienced this with the Summa. I have 2 more rolls to print, 1 I will be doing with print jobs individually (Which sucks on a latex machine, but oh well!), second one I'll just print a full 150FT in 1 cut file to see how the summa handles it. It beats me having to hand cut like the other 4 rolls I'll be doing at least.
Not sure if the cut data is adding multiple registration marks? or whats going on. Could be an issue with The summa software - Clicking skip just skips the mark completely, so not sure if its asdding double reg marks, or something else with the cut data onyx is generating.... or if its somehow the summa software, but everything I've printed aside from these files has worked with no issues.
Pauly
Printrade.com.au
Should check the file first in the summa software.
As much as we like to blame onyx as it's the natural thing to do, which... it probably is onyx's problem.
im not familiar with the summa software, but see if you can do a dry run.
Check the reg marks on the file as mentioned and see if they're doubled up. or something weird.
I've had weird things with optiscout before. i've also had onyx generate reg marks 2mm out of the actual position too.
ikarasu
Definitely onyx. I dont know if theres a double reg mark... in summa software I can select it and delete it, but it goes away - so it acts like theres only 1... but its weird how it'll read it, then try to re-read it....then say its already been read. I've been meaning to open the generated file and see if I can notice anything with it...
I did print another roll with print files individually.... And it worked fine. Also printed a full 150 FT roll... and it printed and cut fine, though it was a bit laggy reading the whole file on our crappy summa computer! So its definitely something to do with the original issue where you select a sheet size and onyx auto generates based on your sheet size.
Saying that... I havent tried to replicate it, its been a busy few weeks, and I just finished the job. Cutting up 4 rolls by hand was a pain... almost tempted myself to re-print them once I knew it worked...rather waste $1000 in material / ink than spend the days it took to do that again! :roflmao: Sometime this week I'll print a few things sheet fed / summa designated and see if the issue replicates itself... could be just a weird one time glitch, but I tested 3 of the 4 rolls... so I'm guessing its not a one off. Easy enough to test though!
evoprinting
We used Postershop 22 for 2 years with good results. Upgraded in January. We're having so many problems with Thrive 24 it's completely ridiculous. We use Onyx RIP to send print files to our Epsons and Cut files to Go Produce.
1. Onyx was adding the random, duplicate reg marks and we couldn't finish cutting. Summa helped with a work-around.
2. Cut server will not accept the material profiles from Go Produce.
3. Cut sever will not send SGP files to Go Produce.
4. Onyx will not send the proper type of cut profile (ie kiss-cut is sent as thru cut, thru cut is sent as draw etc) Due to this issue we are unable to use the barcode scanning feature.
I was told these are all known issues but not given a work around or date on when to expect these to be fixed.
Beyond frustrated.
balstestrat
Problem Solver
Beyond frustrated.
You can get rid of all 4 using .oxf and listing the cutpaths correctly with the tools you want.
But I've had sgp work just fine as well, not importing materials but only ^
Hmm, maybe I don't understand the new quirk. When I read the OP, it sounded like Onyx 24 would only honor the cut path in the first page, and not apply the cut paths in all of the pages. The cut paths are the same in each page, the only difference would be a number in the artwork. I do the variable data merge in Illustrator, and save as a PDF with lot's of pages.
I haven't upgraded yet, so I have no way to tell what would happen.
i believe someone mentioned that you could upgrade by installing as a separate program. keeping the original version 22.5 intact and functioning
assuming you have enough free space, that might be a really good idea
