Onyx Cut-server double line?
Tatonka
I just ran a file through Onyx postershop, printed on my Epson S80600, and sent to my Summa S2T160 through cut-server. It had 7 different files on it, and at least 5 of them double cut with a tiny offset, so they're ruined. I can't find anything different in the file setup, they were all created using the same template, and nothing is different in the cutpath layer in illustrator.
It's almost like instead of following the center of the cutpath line it tried to cut both sides of the line, but only on some of them. All the cutpaths in illustrator are strokes, with the same stroke thickness, and no fill.
Has anyone run into this before and knows how to fix it? Does the stroke thickness have anything to do with it?
unclebun
If it cut double lines, then the double lines are in the layout that was sent to it. If your layout is one like we often receive where objects get doubled when exported, usually because they have a stroke, then both filled object and the stroked object without fill may have been given the CutContour color for a stroke.
Tatonka
Our layouts are created in-house, and I'm using the .eps files to print. I've dug through the files in Illustrator and can't find a single difference in the cutpath layer in any of them, and there's nothing else in the file that has lines where the cutpaths are. It seems odd that only some of the files would do it.
Dan360
I have this happen occasionally with some files our other designer has set up. Same thing when I look at them they're fine but I get the double paths in Onyx. I think it has something to do with how the actual path is made or how the file is saved, I should watch her set the file up next time to see what's happening.
unclebun
Break the object apart in illustrator to see if there are multiple paths combined together that look like a single path. That's what we find when we receive files created in Illustrator.
C
ColoPrinthead
Guest
I used to get the double cut lines with Onyx and was told by a member here that making the cut path a solid object with fill and no stroke is a work around. I guess Onyx cuts both sides of the stoke.
Tatonka
This looks like it'll fix it. Although it's an annoying way to fix it. I'm also trying making the stroke as close to 0 as possible without being 0, to see if it'll double cut or anything.
It's definitely cutting both sides of the stroke, or that seems to be the issue anyway. I can't figure out why some files were doing it and some weren't, literally everything I can find in illustrator has them exactly the same. Heck, they're all from the same customer using the same template, so the cut layer was created from a single original file.
edit: making the stroke close to 0 didn't work, it just cuts twice in that spot. But making it a fill instead of a stroke does work.
iPrintStuff
Prints stuff
Never had this problem with strokes, only get it when the file had been flattened and the “convert all strokes to outlines” was left checked. If you zoom in really close, when you click the line does it give you a path in the centre or a path either side of the line?
Tatonka
path in the center.
Flipping it to fill instead of stroke fixed the problem for me 99% of the time.
iPrintStuff
Prints stuff
Odd! Never had that problem but good to know how to fix it! We export all our files to PDF so hoping that’s just an eps issue.
Danielsdzyn
So I may know what the solution to the double cutting is.
I've never had this issue when doing pdfs so, when saving EPS. Go to "save as".
Beside "preset" select "custom"
then UNCHECK "convert all strokes to outlines"
I'm trying it now. Should work.
as stated above,
no work around necessary, just set your cut swatch as an object fill....NOT a stroke.
(a stroke is two lines offset from object when converted to paths. an object has one line, at its true shape)
ikarasu
This comes up pretty often. It usually happens when you're cutting something with a transparency, such as a PNG.
The cut color gets copied into the transparency and this creates double cut lines.
If you flatten your image, it'll go away 99% of the time and only do 1 cut line.
