C
cruizer
Guest
I am Running Onyx X10, Printing on Mimaki JV3-250SP, and cutting on a Gerber Odyssey. When doing a print-to-cut, it almost never cuts correctly. The the top right (start) and bottom left (end) will almost always be perfect, but in between either the Y-axis or the X-axis will drift (usually Y, but never both). I can stop, reset and restart as many times as I want, but it will always give me the same result with that cut file.
I calibrate the cutter every day, and all other basic cuts done on the plotter turn out just fine.
Any ideas? Any way to test any theories?
