Perf Vinyl Falling off after several months - Best way to fix?
RockinRobLee
Hi All,
These graphics were installed this past October. Roughly 48" x 48" perf vinyl panels with optically clear lam applied to glass. 3M Edge sealing was used on the edges as well. Recently, to varying degrees of severity the vinyl is falling off (photos attached). Confusing as several locations have zero issues with the exact same graphics, material and install method. Most important question is how to best fix this and make it hold in cold weather? Heat gun and more edge seal were used at one location but that is again lifting. Any advice is appreciated!
Texas_Signmaker
Very Active Signmaker
I had a problem with perf but it didn't look like that. I think your window might not of been cleaned correctly. The corners can be slick and that stuff needs to be cleaned well
RockinRobLee
That's the thing - they were squeaky clean, alcohol and all. Same as many other installs that worked fine too.
