Pole Pocket
Bannerday
I'm doing a 3 x 8 banner for a parade. Putting pole pockets top and bottom.
How much extra do you charge for pole pockets?
Letterbox Mike
Figure out the flat size of the banner and charge based on that. If you want a 3' tall (finished size banner), with a pocket for a 1.5" pole, You'll need to add an additional 3.5" of material for each pocket (3.14 [pi] x 1.5 [pole dia.] + .75 [slack in the pocket] + 1.5 [material for hem] / 2 [half of the pocket will be the face of the banner]). So a 36" banner will require 43" of material.
Bannerday
So if a draw I line 3.5" from the top and bottom and run the tape along that I should be good to go?
Using 36" material I would have a finished banner of 29". Correct?
I don't do pole pocket often, so I want to make sure I got it right.
