Poster pricing?
ChiknNutz
I just spoke with a local graphic designer that I do a lot of work with for solvent prints, but no posters...yet. In some cases, they need to be mounted onto "chipboard" (thin cheap cardboard)...does this paper you print on with this type pf printer already have adhesive, or do you need to mount with an add'l adhesive product (what sort if you do it that way)?
Pro Image
No the paper does not have any adhesive on it...........If it needs to be mounted I use the thin gator board with the adhesive applied to it........Not much of a call for mounted prints though........We can get adhesive backed paper for .36 a sq if needed.......That is what I would use if I had a sizable order that needed to be mounted.....
Of course all my prices above are without lamination.........
steve b
I am interested in a printer for posters....Ya know the ones that companies give away, (Snap On, Kendall, Budweiser and the ones with the Hot chicks). How the hell would these cost that over 10 bucks a piece to produce? They are printed on thin glossy paper and usually come in a roll with a rubber band around them. There is no way these are worth 90 bucks a piece. So with that said, What kind of printer is used for the posters I mention?
Best Regards,
steveb
Pro Image
Best Regards,
steveb
Large Offset presses that can spit them out at 1000 per hour...........
oc63rag
I sell media for inkjet printers. If you're using an HP 5000 series (or comparable) you can get a 24# coated bond for about $.04 per square foot. You can get a 38# coated bond, with adhesive backing, for about $.21 per square foot.
A 24# coated bond is fine for light ink coverage but I wouldn't use it for posters. You're asking for head strike and a saturated sheet.
If you need higher quality than either of these options I'd go with an adhesive backed polypropylene for about $.24 per square foot. You'd get a tear resistant film base and the appearance of a more expensive photobase paper.
S
Stan B
Guest
Posters are very confusing to me too. Yesterday someone came in for 25 posters (20 & 5), 3'x4', 3 color on a heavy glossy paper. After me quoting these he said he got another quote for $18 ea... I said - "God bless"
I could rip my a...s off and make it for $16. But is it worth it?
mark in tx
I print posters at $4.00 a sq/ft, with artwork provided by customer and print ready.
The way I look at it, with my digital printer I can provide the short runs that traditional printing houses can't or won't do.
Call around to offset or litho printers and compare what they charge for short runs.
javila
The price you'll quote for 25 will probably be a hundred dollars under what an offset will quote for 100.
Posters in quantities are a hard hard sell on wide format printers.
2-5 is the sweet spot for selling posters on these machines.
Print-Kwik
We get $8.25-$6.25/SqFt for 24"x18" posters off the Mutoh
We sell them for $0.83/ea. when putting them on the press. (min. qty = 1000)
