Price Check: 300qty .040 Alum 4" x 6"
bannertime
Got a quote request this morning for 300 white 4in x 6in 040 aluminum signs with black numbers and text. Each sign would be different. We were going to do these out of black cast vinyl on pre-cut blanks. We were coming up with something like $4.66 each. Which we do believe is slightly on the higher side, and we do have a bit of room and could go down to something like $3.50 if pressured.
Our quote was not accepted, and they said the one they did accept was considerably less. I'm curious what someone with their own sheer or maybe flatbed/cnc route might have quoted.
That's just a little over 2 sheets. Why not send them to a flatbed, THEN sheer cut 'em ?? You'd be well under a dollar each.
Heck, .040, you can cut on a paper cutter, if need be.​
bannertime
That was similar to our original plan, but we don't have room for a full size sheer right now and not sure of anyone in the area with one either. Last time we tried using our guillotine for cutting thicker materials we had a hard time keeping the material from moving. We have looked for a 36in sheer, but not having much luck on that either. Then we'd do them in 2x3 blanks and cut down to size.
Our quote from the supplier was $402 to cut down the blanks, and that was the cheapest of the three quotes.
Also, since it's for a tree farm, and they'd be row numbers, we figured using a cast vinyl was better for the long term.
