Price Check........help Please
danger
Not sure on how many have seen the loomis fargo trucks but this are almost the same to a t .....The job is remove the current lettering and install the new...... What is on the now is printed reflective been on for two years and the intstall is the same there is about 60 trucks total i was wondering what others would charge
THEY ARE SUPPLYING THE GRAPHICS ALL LABOR
About 12inch circle on doors
Above windshield banner text
6 to 7 foot logo on rear sides
4 foot logo on back doors
any help would be great
Mardi
Removing reflective is a major biach... would cost them a lot more for removal than for installation of new graphics.
Do one first before you commit to the cost!
Mrs. Uneedasign
We charge our shop hourly rate for removal. I couldnt agree more with giving one a try first, also how old is the reflective thats on there? We just removed some chrome that was on a truck less than 9 months and it was tough. I have heard reflective is the worst. Maybe invest in a vinyl zapper. Tell the customer you need to do one to get a time frame,see how that goes. $75.00 an hr here in these parts for removale.
Ken
Well, this is dangerous..should be right up your alley.
Reflective is difficult to remove. Someone suggested a vinyl zapper..That is what I would try. Also suggested was: try one, see how it goes then give a quote. Thats what I would do. Could be a pretty lucrative job. Don't forget the boredom/grunt factor surcharge...
Ken
DO NOT flat rate removal of reflective! It is an hourly task, not to mention the vast number of scrapers, chemicals, etc. etc. that you will be using.
In many cases we have found it was easier and cheaper for the customer to repaint than to pay us to remove reflective. For those very few that we have had to remove, the labor cost has always exceeded the cost of the new vinyl and installation.
If the customer doubts you, hand them a scraper and watch them try and remove one inch of old reflective. They always understand after that.
This does not apply IF the reflective was installed over cast vinyl - but is usually not the case.
Mark L
Vinyl Zapper doesn't recomend use on reflective. If you do use this be prepared to go through lots of wheels Keep that cost in mind too.
agree with all the wise responses quote this as time and materials, charge your hourly rate and get busy it is a tough job and in my opinion not enjoyeable in any sense of the word....make sure you are being paid correctly or pass.
Jillbeans
For the vynull removal I would charge an hourly rate of $75/plus materials.
I saw on another forum that you tear off the first layer with a L'il Chizler or whatever, then apply masking tape to the silver layer, squeegie, and pull off.
I have also heard good things about the use of a wallpaper steamer. I usually use a hair dryer, Chizler, and rapid remover...and TONS of elbow grease and fingernails.
For application of their graphics I would charge $50/hour plus materials.
I remember removing reflective from a firetruck once. I always try to give the vollies a fair deal. I charged $25/hour and it took EIGHT hours to remove the stripes/lettering off two doors and the name off a back panel. Not fun.
Love....Jill
mbarden
I have used Vinyl Off from CrystalTek. It is amazing stuff. Use very carefully and apply only to the vinyl being removed as it can damage clear coat and paint.
MB
Arlo Kalon 2.0
This was an important comment I think should be emphasized. It's more of a Tips & Tricks, but the remark was made in here.
Reflective and SignGold vinyl alike are incredibly difficult to remove - usually, ya lose yer arse on the 1st job ya quote removing this stuff! BUT, if ya work into your design say a black outline that you apply solidly as black vinyl, and then do a 2nd layer of your refl. or signgold vinyl on top of that, the eventual removal of it becomes the easiest you could imagine. I've removed SignGold that was on top of black like this and had it all come off as one big piece in just a couple of minutes. It's a very big help to know this if like me, you have a regular customer that changes out his fleet frequently and you have to do the removal.
johnnysigns
not ALL reflective is difficult to remove. if the material is controltac comply reflective, which is certainly possible considering it's 2yrs old, it should come right off w/ mild to medium heat.
i would'n't price out any removal w/out doing some test pieces beforehand. if you can get away w/ an hourly rate than i'd go that route. more often than not that's not the case. most times we give them a price, but stipulate that if the material is difficult to remove and we run in to problems that there's a higher fee they'll incur for the removal where you don't lose your bottom line.
