Price Check
slappy
So, I did these signs. 4-10"x4' d/s alumalite for $85 each, and the guy forgot to add something to this one which means i have to peal only the top line off and replace it with Mark A Goral, Ph.D., DABPS
my question is how much should i charge him for removing, cleaning and replacing the vinyl?? It's oracal 651. I'm not sure. I got 15 minutes into peeling the top line off on both sides and cleaning it.
Thanks in advance
petepaz
are all the signs 2 sided might have went a littlie higher on the price of $85.00
but based on what you charged for the main signs you should be able to get $15.00 per side
TheSnowman
Do you happen to have the MBX Vinyl Zapper? If you could use that instead of like a little chizler or something, it would really speed you up. I just charge my hourly rate for removal of vinyl...but I know some people really crank up the charges on that kind of stuff.
Doyle
I would sell him a little chizzler for $2.50, and charge him for applying the new lettering when he brings the panel back...
thesignexpert
Keep it simple and charge again, retail, for time & materials. Take the time to educate the client on exactly why this needs to be done (short answer = you don't do quality work for free :wink: ) Just make sure you don't short yourself on the time it is really going to take you to rework the job.
Tim Evans
The Sign Expert .com
"Practical Help for Sign Professionals"
Pro Sign and Graphics
"A Pro Sign made Easy"
