Price for A-Frame Sign
Erin
Need some help pricing out an a-frame sign. The customer wants a price for one 24"x36" and also a price for one done 32"x48". The a-frame will be just the basic metal a-frame with the sign done on corplast.
Sign will be 2 colours (green and black) and will also have a digital print that will be approximately 8"x8" in size for the smaller a-frame or approximately 10.5"x10.5" for the bigger a-frame.
Any suggestions on price for something like this?
myronb
My supplier doesn't have a 32x48 but here's where I would be on the 24 x 36:
Frame - $40
2 Blanks -$5
2 digital prints $10-$15
Vinyl - Maybe $5 w/ app tape
Total Material cost - $65
I'd double that (or a little more) & go with $145.00 +/-
Regular 2 x 3 Real Estate Goes for about $90 so that seems about right.
OldPaint
you can build A-FRAMES from 1x3 wood...2 hinges, and get a better price for it....and still use a coro sign panel.....if you build it then size is not determined by your supplier......hehehehehe
jimdes
I'm with OP on this one. A wooden A-Frame is easy to make and you can do a lot more with them than metal frames. A 4' X 8' sheet of MDO will yield 2 - 24" X 36" A-Frames PLUS leave two 1' X 4' strips for a couple OBDS signs.
Monetarily speaking, that's $54.99 for a sheet of 3/4" MDO that will yield about $600 in finished signage. Then there's about $30 for the paint. Since I started doing some of these, I've been having a ball.
njsigns
Just wondering if you have any photos of what the finished product (the A frame) looks like?
So many great ideas on this site...
Thanks,
Gene
Erin
That's for the advice everyone...however my client has indicated they want to go with one of the metal a-frames, not wood.
Si Allen
Here's a typical A frame that I do...piani hinge on the top. I use 3/8" MDO.
The MDO has enough weight so that the wind doesn't blow it over!
OldPaint
what si does is the simplest way to produce an A FRAME sign. cut the sign from 1/2 or 3/4 MDO....piano hing top, chain across bottom so it wont open any wider then it needs..and you done....but unless you can buy pre painted MDO and you will still have to PAINT(bad word for most who dont know how to)and seal the cut edges.
the one i was suggesting is made from 1x3 or 1x4's. and its nothing more then 4- boards cut to heigth,and 4- cut to width.
to make one side you lay down 2 LENGTH boards, on the top you place a WIDTH board, and then you place a width board near the bottom, say 2-4" up from bottom...now attach and square these 4 boards.....now turn it ove and you will need a shorter width board that will fit on the front side on top of the width board, and will fit in the space between the 2 LENGTH BOARDS... make sence? now do the same for the other half, hing together short chain bottom, and then you can put 2 PIECES OF CORO on the outside as your sign......most of the time i dont even paint these....cause of price....they dont want to pay for my time to paint em ...fine
