Price help for installing viny on awning
Erin
Just wondering what some of you would charge to install cut vinyl on an awning like the attached pictures?
Is there anything special I need to do to the awning before installing the vinyl?
Any help would be great!
imaSIGNr
If the vinyl is to be placed on the lower part there I would think you could clamp a piece of wood ( MDO ) on the back side and have a helper there to hold it so you can push against it. ( on the side area anyway )..
Up front you may have to build a curved piece maybe from aluminum, curve it to fit and have it attached to wood support....
or after you have it taped up and centered. Cut apart each letter and just have a small piece of wood behind it .
Shovelhead
It would take me about 45 minutes to prep the surface...
and install all three sides. The average person maybe stretch it to
1-1/2 hours. Are you installing already cut vinyl???
Craig Sjoquist
would ....1 .... hand letter copy all 3 sides yes a clamped on piece of alum helps, some areas you pull a bit
..... 2 ....cut a vinyl mask and spray on color remove mask
......3 .... cut vinyl hope for the best replace what falls later or looks bad
13 folds
ENTDesign
Find out what material the awning is made from. The standard PSA vinyl adhesive does not stick to certain materials.
William
I have installed cut vinyl to the canvas type awnings and it stayed on for over a year with no problems. My install job outlasted his business. I just taped it up cut it apart and did one letter at a time. I used my torch before and after removing the premask (just don't burn the awning down). Was a pain and took longer than I thought, but it worked.
- Materials + Mark-up + Install
make sure you charge enough for the install, because it will take longer than you think it will, but doesn't that always seem to happen.
