Price help for letters on posts please
signmeup
Could someone give me an idea of what this type of lettering job would cost the customer? The letters are to be custom cut from dibond and covered in silver vinyl. They will be held on with two sided foam tape from R Tape. Oh and the shop front is cast iron. Yep...it's made from real cast iron....I checked. The customer says they have a quote of $250 installed from another outfit. (That's letters and all) I was thinking that was a little low. The letters are 9" tall and the sign is 12' long
Adrian
SAS
I would let the other outfit have it. There is no way I would even cut the letters for $250
Bigdawg
Just Me
When someone starts telling me what a great price they are getting from another company I tell them "yep, that is a great deal, if I were you I would run with it! But here's my price if it doesn't work out"
Checkers
Hiya Adrian,
It can be done for $250 and you can make money too :)
I'd outsource the lettering to Gemini and let them cut them out of 1/8" thick silver metallic acrylic.
Your costs would be as follows:
Letters - $94.50
Mounting pattern/Tape - $15
Shipping - $15
VHB Tape/Silicon for mounting & Misc. materials - $10
Travel and installation? With a 40% gross profit on materials, you'll have $25 left to spend on install :(
Checkers
Checkers is right... you can do it. However, this is where I would say... 'More power to ya, buddy'. Walk away and see if they call you. Be willing to walk away from a job that doesn't sound good or gives you a bad feeling in your gut.
If they don't call you, you're not missing much. If they call you, well maybe you'll get what the job is really worth and not work for the low overhead/profit margin the other shop is working on. It is your decision what you get paid, not the customer's. You quote accordingly... he takes it or leaves it... not the other way around. :thumb:
Good Luck.
signmeup
Thanks guys. I looked at Gemini and came up with $9.00 per letter. That works out to $198 for the letters alone...no shipping. That was for 3/16 cut plastic. Cut Aluminum was $27 per letter. I figure I can cut them out of Dibond for $13 per letter.
Anyone got a guess on how long it would take to stick these things on? I would need to plot out a paper pattern and then cut the letters out by hand I suppose. Then apply the tape to the backs and apply the letters.
Adrian
signmeup
BTW, I figure the "quote from another shop" is just bluster...or the other shop has different specs. Or maybe a missunderstanding....I'd do cut vinyl letters for that.
Adrian
Checkers
You should be able to knock out the install in an hour, 2 at the most. I'd just use a combination of silicone and a little VHB tape. The tape holds the letter in place while the silicon sets up.
Checkers
Don’t take this the wrong way, but if you’re going to do this in the fashion you’re describing, then your not necessarily looking for a total professional look if you intend to do this by hand in the timeframe you’ve explained.
Unless you’re using a CNC machine of some sort, a band saw, or some die cutting machine or cutting these with a scroll saw, nothing else is going to get you anywhere near $13.00 per letter and still have finished edges. One or two letters with a jigsaw, some hand sanding and grinding might be do-able, but I wouldn’t want to take on that project without the aid of a precise machine doing the cutting. You’re going to need to sand down all the burrs and buggers and then apply your vinyl and hope you get a good edge seal. If this was an interior job, perhaps, but on a storefront like in your picture… more power to you, now… than the other shop.
This looks like you’re getting in over your head to make about… ‘Nothing’ on the overall job.
Remember: The Bitterness of Poor Quality is Remembered Long After the Sweetness of Low Price is Forgotten. :thumb:
signmeup
Thanks for the input. I can cut the letters. I make scale R/C airplane model kits in my other business.
I figure I'm going to quote $400.
Adrian
signmeup
Man, this is an old one! Yes, I got the job. T'was pretty easy to actually do it. I plotted the letters out of silver vinyl, stuck them onto the dibond and cut them with my scroll saw. A little deburring and they looked great. Then I made a paper pattern for the letter spacing and taped it in place on the building. I stuck the letters down with 2 sided tape and silicone. The letters have a pretty decent drop shadow even though they are only 1/8th dibond.
I got my 400 bucks too!
Adrian
