Price Help Please
Sign_Boy
Just wanted to see where you all were at on this.
24 1/4" x 144 1/2" Acrylic sign face 1 Trans color or 1 Trans + Black.
Thank you in advance
Marlene
The material for the face marked up with your usual mark-up. What goes on it? Did you design it? Lay it out? Charge for that. White background with copy or colored with knocked out copy? Wht do you usually charge for vinyl? We charge by the letter and letter size for straight copy and times that by 1.5 for background with weeded out letters. Add in application. Is that any help at all? It's hard as sign shops have different ways of charging for materials and labor.
Sign_Boy
It all depends on the job. I usually charge per liner foot for RTA and other jobs by the SQ foot.
I don't think I could charge by the letter that would drive me insane.
I was figuring $533 for 1 color trans including the layout and $577 for 2 colors.
I wanted to see if I was high or low.
Thank you Marlene for the info.
S
SignTech
Guest
24 square feet at $20.00 square UNINSTALLED and $25.00 a square installed ...... basic layout 2 colors
I think your price is fine 3/16" inch?
high impact
Acrylic is anywhere from $17 - $25 per square foot around here. I'd be right in the middle. For install I figure about how long it will take and charge 2 men from that evaluation/estimate/guess/crapshoot/gamble. ;-)
jdb
$800.00 here, all day long. That includes the install if it can be done off of ladders. If not, extra for the lift.
Sign_Boy
It's about 7' off the ground no big deal there.
800 what's your install rate if you don't mind me asking?
