Pricing A Photo decal
GeorgeJ
A customer wants a decal made from a photo that he is supplying. The decal will be placed on the hood of a racecar. Size will be 24" x 36" and will be printed using a SP300V on calendared vinyl and laminated. Very little processing needs to be done to the photo. We will be printing and installing 3 of these. The customer is a high-end sports car dealer.
What would you charge?
ChiknNutz
First off, I would use CAST vinyl based on the application. Second, I would charge $98.35 each if using a calendered combo, and $118.50 each if using 3M ControlTac.
GeorgeJ
Thanks guys.
The only reason I was going with calendared was that the decal is a memorial decal and will not be there too long.
Checkers
I'm with Si on this. Cheap tires on a sports car will run at lest $150 each and they don't last long.
Design should be billed at $85 - $125 per hour and the decals should be about $125 - $150 each.
Installation is additional, billed at $75 per hour plus travel.
JJ
Just my newb perspective: Wouldn't this be a good application for re-positionable (aka non-perminent) vinyl?
