pricing for 50 sign 18''x12''
Derf
$10.00ea-$15.00ea
However some may do it for less... I'm kind of out of touch with this stuff
Pro Image
Baked enamel is the finish on aluminum and silk screened is ink that is screen printed on to the baked enamel alumnium.......
Checkers
Screenprinted on coro would retail for $4.99 each. I would get a 45% discount from that price through my wholesaler.
Design, shipping & handling is additional.
Checkers
What you have there is worth about $6.00 to $6.50 ea. based on a 50 count.
You have one slight problem... if these are 18" x 12" and you have a green border [or any color] going out to the edge, there is no gripper space available, which means either a messy job or you need to print to a larger size and then cut it down after they dry.
For anyone interested, save yourself money and don't design silkscreen jobs out to the edge. When picking these panels up, there is no place to grab a hold of to pick them up, so keep your layouts or designs in at least 3/8” all around and start saving money and headaches. :thumb:
Checkers
Gino brings up a good point.
Most wholesale screen printers will want a ½ to a full inch to to play with. The one I normally use specifies a 1" margin. So, on a small sign like this, you'll loose a lot of valuable real estate. :(
Checkers
TheMattMan
We would only get about $2.50 a sign for that size and qty. Luckily my screen guy only requires a 1/4" gripper.. I can't imagine having to leave a 1" around the edge...
threeputt
$4.88 each, printed 2 up on a single 18"x24" Corex blank, one side/one color imprint. (simple layout) Table saw rip after drying.
