ok i am gonna take the front off to get to the lines but i am unsure of how move the heads and park them back into the cap station...thanksFirst of all what is the results of the drain lines and the other things first.
Using the swab under the head won't help unless the drain lines are clear. Also report back on the pooling or not in the captops.
Now if you do press the swab under the head (on a scale of 1-10 and 1 being soft ) I would say about a 3 or 4. If the swab is too wet you would want something under the area so you don't get fluid all over or on something that should not get wet. I would press up a couple times, filp the swab over and repeat. Flush the swab out and do again. Then the cleaning cycle but if the drain lines are plugged the pump won't do its thing.
Ok took front cover off removed drain line from pump shot air through it with syringe no restrictions...put drain line back on....held the cover switchFirst of all what is the results of the drain lines and the other things first.
my question is how do you know when your head is done...with what i got with print test i printed 2x2 inch squares that looked ok but with these nozzles bad what effects does it have? Thanks
4 yrs old and on my third set of carts which most of the ink it went done the drain....like to know were to read what it actually done in 4 years ..i know minimal....Most times unless your heads hit something they can have a perfect test print but still be at the end of their life. I had one head that the black started to band and no matter what I did it never stopped until the head was replaced. The test print was still perfect.
You should be able to see the shot count in the menu some place and the manual should say how many billion shots a head should last. If you are close that is one way to know it might be the head.
The way yours looks, it could be cleared up with some cleaning.
Overspray may be another sign of a bad head.
thanks i have a service manual for a sp300 dunno if they are same..Do you have the service manual?
In the old Rolands the info on history is in the service menu. I would think it should be similar in yours.
If you want send me a PM with your email or phone#.
With a premium subsciption you should be able to get it on this site.
