Printing Styrene with SP540V
rjssigns
Anyone have any wisdom to share regarding printing on styrene? The only styrene we print on now is for back-lit and it looks great. Would the non-backlit use the same profile, heat settings, etc...?
CS-SignSupply
If the thickness is the same, I would think the profile would be acceptable for use on both back-lit and non. some variation may occur.
tgrinds
Typically, if the surfaces are similar, you shouldn't have a problem. I'd try a small test job and check the results. Good luck.
