Peter Corp
Hi there, I don't post very often. It only seems to be when i have a problem.
I have a GCC GRC 132S vinyl cutter that I seldom use. Our main cutter is 600mm wide.
When I try to start my GRC 132S I load the media but the cutter blade will not return to the start point.
Carriage slams into the fan end and will not return to the start point.
Message says to check Y motor. Not sure about this. Any help would be appreciated.
