Hi guys
I've been reading previous threads, googling etc etc but i'm still no further forward.
I need to profile some media, i've been using the generic profiles but i'm getting really bad results with a couple of vinyls, I always intended to make my own profiles but I need to get started sooner rather than later and as I have some free time, i thought I would start now.
To save time, hopefully I can explain what i'm doing and you can tell me what i'm doing wrong and tell me the next steps and for those who will do this, hopefully they can follow along. I will try to write a full guide once I have it perfect that could maybe get pinned?
I'm using an I1pro2, I have i1profiler and babelcolor (trial) if that helps and i'm using the latest versaworks duel. My printer is a VSi-640 and i'm running CMYKx2.
So here goes:
PART 1: VERSAWORKS
• Insert media into the printer and set bi-directional and feed adjustments correctly
• Open Versaworks and add my spectrophotometer (In this case it's Gretag Macbeth Eyeone for both options)
• Open Queue A settings and set
• Layout / Scale - 110%
• Quality / Colour Management - Density Control Only
• Mark / Print Job Properties - Quality Settings & Date/Time
• Printer Controls / Feed Settings - Printer Settings
• Printer Controls / Heater Controls / Custom Settings - Print Heater: 40º & Dryer: 50º
• Click OK
• Go to Media / Media Explorer and create a new profile
• Name it i.e. Banner and give it the Banner template
• Select the new media and click Print Quality Settings
• Go to Calibration Settings / Print Chart and make sure the limits are 100%, 100%, 100%, 100%
• Click Print chart
• Once the chart has been printed on your required media, you'll need to measure the chart, to do this I do the following
PART 2: i1PROFILER
Open i1Profiler
• Click User Mode / Advanced / Measure Chart
• Change the rows and columns to match the print out i.e. 4 rows, 21 columns and click next
• Select the measurement mode to Duel Scan and Calibrate the i1Pro2
• Read the patches
• Double click on the darkest black patch (Far right)
• Change the CIA Lab to CIA Lch
• Now go through all the black patches till you see the highest c values under M1 (most likely in the top 90% and above) and write it down i.e. Black 95%
• Do the same for cyan, magenta and yellow
Mine are as follows
Cyan: 100%
Magenta: 95%
Yellow: 95%
Black: 100%
• Save the data to your desktop as a .cmxf file
PART 3: BABELCOLOR PATCHTOOL
• Open Babelcolor (trial)
• Open your saved .cmxf file and select M1 and click proceed
• Change the rows to 4 (to match your printout)
• Take a look at the info panel, towards the bottom of the info box you should see ΔE* (Delta E)
• Now select the darkest black patch (Far right) it'll now have a white border around it
• Now hover over the previous black patches and look for a number between 1.5 and 2 under ΔE*, closer to 2 the better and make a note of the patch i.e. 85%
• Do the same for the other colours
Mine is:
Cyan: 95%
Magenta: 85%
Yellow: 85%
Black: 90%
• Write your figures down
PART 4: VERSAWORKS
• Go to your media your created in media explorer and open print quality settings
• Go to Print Chart and change the Single Color Limit to match your findings
• go to fine Tune and adjust the graph so there are no spikes and just a relatively smooth line
• Now go down to Total Ink Limit / Print Chart and Print
• Once printed, take a look at the chart and identify (by sight) when the colour is the brightest and do this for each row
• the top 3 rows has mine on red 200, green 180 and blue 160
Now on to actually profiling the colours.
So far is all this correct??? Any input???
So here goes:
PART 1: VERSAWORKS
• Click OK
• Click Print chart
PART 2: i1PROFILER
Open i1Profiler
• Read the patches
Mine are as follows
Cyan: 100%
Magenta: 95%
Yellow: 95%
Black: 100%
Mine is:
Cyan: 95%
Magenta: 85%
Yellow: 85%
Black: 90%
PART 4: VERSAWORKS
