Proof with invisible water marks
JBurton
Signtologist
That was a bit of a rabbit hole. I found a guy who describes the process of generating a void pantograph in photoshop. This looks ideal for what you're doing, but then it will have to distort your artwork in order for void to show up, which would kindly torpedo the whole sales ready art you're trying to present.
Security paper is kinda the opposite, my bad. It has a watermark that can't be duplicated, in some cases it will show void, but in those cases, monkeying with the resolution on the scanner can make it go away.
I feel for ya, having some art ripped off is not fun. But, the bright side is that a customer who will do this to you is not a customer you want. At best you can slap a copyright protection bit of lettering on it, or 'use of this artwork by any vendor other than majic signs llc is in effect an agreement to pay majic signs llc for their artwork, valued at $500.'
BigNate
From the copier side - if you have the capabilities of making a dot so small that most scanners cannot get a clean scan, then make up a light graphic from a half-tone of this size dot - then the dot gain/loss from scanning will make the fact it was copied very obvious. (similar can happen with a slightly larger dot that is too small to reproduce without significant dot-gain on any consumer level printer - then the daker image shows up in the print....) You can also mess around a bit with changing frequency and amplitude modulation of the artwork to increase the effectiveness (have areas that maximize the effects on machines that scan poorly and other areas that maximize on the printers dot-gain -- 2 tiny dots close to each other that can be scanned by a high-end scanner will usually combine from the dot-gain when printed on a cheap printer, making a print that is visible.)
Eforcer
Sign Up!
How can we apply an invisible water marks to a printed paper that when copies are made it will show the water mark on there copies?
Type: PROOF PROVIDED BY _____________ <----------Bold font, and fill the area, bring opacity down to the point of vanishing & place over the wok you have done.
myront
Dammit, make it faster!!
Not sure I understand the workflow? You have your "working copy" and right next to it you have your "proof copy" with your own watermark added. Our proofs are almost always a low res png anyway, so we don't use a watermark. Yes, occasionally we have to explain what a "proof" is when asked why it's "fuzzy". A proof is just to ensure the quantity, material, size ,spelling etc. is correct.
