Properly Masking, Storing and Transporting Cut Graphics
Hey everyone. We produce a good amount of vehicle graphics using 3M IJ680cr with 3M 8518 gloss overlaminate (approx 20-30 vehicles per month). I've found a few flaws since I have recently had to do the installs myself due to being short staffed and am hoping for some suggestions here on how to correct our issues.
Our current process - Production will print a 48in wide sheet that has the printed graphics, laminate, cut on the Graphtec, weed the excess, mask the 48in sheet using RTape masking, roll loosely print side out, put inside an old vinyl box. What I have found is that the graphics get flattened inside the box and during transport, causing tunneling issues. I've also noticed some masking rolling and sticking to itself, causing issues during installs. When the vinyl/masking flattens it creates (what appears to be) stretch marks that won't go away in the printed vinyl (see pics attached). Not sure if this is cracked ink or what.
My thoughts to correct this issue. Replace RTape with 3M SCPS-102 Clear Masking as this is the suggested masking on 3M's product sheet. Purchase 6in x 48in tubes from u-line and roll the graphics print side out around the tubes for storing and transporting, and then wrap the graphic in kraft paper for protection. Not sure exactly the best way to roll a 48in x 120in sheet around a core effectively though. I'm thinking we lay the masked vinyl face down on the work table, set the tube at the edge, tape to the core and then roll by hand manually. Any suggestions or equipment that'll help with this process more productive would be appreciated.
Thoughts? TIA for the help and suggestions.
Texas_Signmaker
Very Active Signmaker
Humidity is the problem. Just do what the manufactures do when you open a new roll. Roll it tight on the tube. Tape the ends to the tube then tape it to itself when it's all rolled up. Wrap it in plastic.
Not sure how to automate the process... you're only rolling 10' so that doesn't sound like a whole bunch of time being used to roll it.
Precision
We prefer not to apply the masking until the day of the install. We will weed the graphics and either lay then on a table or loosely roll them with the graphics out. On the day of install morning we will mask and roll loosely again.
I hope this helps.
Snydo
When performing local installs, I wrap premasked graphics around an empty tube that banner material comes in, and as long as it's snug, you rarely have tunneling issues.
JBurton
Signtologist
This is how we do it. It adds a nominal amount of time to mask once the vehicle is here, but saves sooo much time in not trying to 'flatten' the graphics back out or anything of the sort. If we are prepping a lot for an offsite install, I bring each piece up to my air conditioned office to store until time to go.
That one wrinkle should be easy to fix right before install, but you have to catch it. remove premask from that area, heat it until warm, let it air cool and it'll relax back to flat. After install you can try heating the p*ss out of it, and it should smooth out, but the wrinkle would likely still show until its been baked by the sun for a month or so.
On the installed constable vinyl, why did you layer the letters over the stripe? Or at least, why bother to weed the white between the stripes? The potential for noticeably different white points between the paint and vinyl is low whereas the lines showing under the text is plain as day.
