Putting Gloss Overlays on a Matte finish Wrap...Suggestions??
Tek Wrap
We are wrapping a side x side with a wrap that has a matte overlaminate. the customer wants some stripe overlays in a gloss finish. In the past I have had issues getting wrap to stick to 3M matte overlam. Anyone know a good combo for this, or done this successfully?
Can you find a suitable color using regular die-cutting vinyl ?? That should stick without a problem.
  • Agree
Reactions: 1 user
ikarasu
Are you using 8520? We overlay on it a lot without issues... If its flat, or semi curved you'll be ok. If you're going into a big recess... it doesnt hurt to primer it.
Heck... if you know where the strip is going, you can use Masking / knifeless tape and then primer everywhere the stripe will be, go overtop of it... remove the masking / use knifeless if thats how you're doing the stripe, and it'll pull both vinyls off before the gloss would lift.
  • Agree
Reactions: 1 user
Tek Wrap
Double checked my info.....we used an avery, matte, cast lam previously. So maybe the 3M 8520 will work better with overlays. We will give it a try! Thank you!
